I've been doing alot of work on my phone.... Way too much to go into here.
Anyways.. I'm about to brick my phone while testing something. I need to use JTAG to bring my phone back to life. Does anyone know of some code that can run on an ATMega to perform JTAG uploading of a firmware?
I think usually you'll need your JTAG to emulate some particular JTAG dongle supported by the host-side software for un-bricking/programming/whatever. And the chances that an arduino can emulate that particular JTAG programmer are rather slim (as far as I can tell, JTAG is a big lie. They went and implemented a supposedly generic, hw-independent, multi-vendor standard for manipulating hardware, only to simply move the proprietary bits to different levels of the communications hierarchy. Roughly equivalent to "our MSDOS-running computer has a different graphics interface than the IBM PC, and we're not going to tell you how to use it." Grr. I'd love to be proven wrong, though.
The Altera USB Blaster is a FT232 based design (not to be confused with FT2232), if he had a non-UNO version, he might be able to hack it, the USB Blaster is supported by OpenOCD
frank26080115:
What Arduino version do you have? Uno or older?
I have an ATMega. 1280 I think. I know JTAG should be possible with the wiring library. If it can be done with a slow paralell port, it has to be possible with an 18mhz Arduino. JTAG is possible. I just need a library or program to use.
I have the data and a memory location to write. I just need an interface to write it with. JTAG works. All I need is a program for the Arduino. I don't have a paralell port on my computer, or it would be pretty easy.
