i managed to get this gmail notification working, all I need is to get the LED to Flash until it gets the No (N) from the python script?
// led wired + to pin 12, resistor to positive +5v
int outPin = 13; // Output connected to digital pin 12
int mail = HIGH; // Is there new mail?
int val; // Value read from the serial port
pinMode(outPin, OUTPUT); // sets the digital pin as output
Serial.flush();
mail = LOW; // start off with lights out
// Read from serial port
if (Serial.available())
val = Serial.read();
Serial.println(val, byte(0));
if (val == 110) // n = 110 in dec
mail = HIGH; // HIGH is off because led is connected to +5v on the other side
else if (val == 109) //109 = m in dec
mail = LOW; // LOW is on because led is connected to +5v on the other side
// Set the status of the output pin
digitalWrite(outPin, mail);
Thanks for the reply, i started with the 'Blink' example but no joy, will try 'Blink Without Delay'
Worked Thanks!
// led wired + to pin 13, resistor to positive +5v
int outPin = 13; // Output connected to digital pin 13
int mail = LOW; // Is there new mail?
const int ledPin = 13; // the number of the LED pin
// Variables will change:
int ledState = LOW; // ledState used to set the LED
long previousMillis = 0; // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 1000;
Serial.flush();
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = LOW;
ledState = HIGH;
// set the LED with the ledState of the variable:
digitalWrite(outPin, ledState);}
mail = LOW; // HIGH is off because led is connected to +5v on the other side
mail = HIGH; // LOW is on because led is connected to +5v on the other side
The so-called "blink without delay" procedure doesn't "block". It always runs in the same amount of time. It simply calls millis() and returns a bit value that is toggling every n milliseconds.
Try values of 8 thru 11 for bitcolumn and pick a speed you like. Put this code in place of the digitalWrite() you have at the end of the loop. You will have to define flashState somewhere.
