How to kill a process after uploading a sketch through the IDE?
I have a sketch that uses the Parse library (see https://www.parse.com/docs/arduino/guide#getting-started). The sketch uses the Parse push service (Parse.startPushService(); ).
However, when uploading a new sketch, the current 'parse_push' process on the Yun starts using a high amount of CPU, blocking the execution of the new sketch. Apparently, this process is not terminated properly when a new sketch is uploaded.
How can I run a script (e.g. 'killall parse_push') after an upload of a new sketch through the IDE?
When I manually execute this command, the new sketch starts running.
Thanks for your help.
Parse library has two packages:
parse-embedded_1.0.1-1_ar71xx.ipk parse-embedded-yun_1.0.1-1_ar71xx.ipk
source code:
"git://github.com/ParsePlatform/parse-embedded-sdks.git"
Test latest packages ( 5 days ago)
or drop a line at github to ask 'killall parse_push' at start up include at source code.
