How to know if device is on or off.
Hello all,
I have a message in a display that tells me if the device is off.
Let me give you some more info.
I have a Caliper (measure device) connected to a display.
When the caliper is off i let it know in the display with the text measure device is off.
Know i wanted to know if there is another way to do this?
Because i used the ("int decimal = 0;") for it.
If decimal = 0 i know the device is off and when it is 1 or higher i know the device is on.
And if i turn of the device it wont go back to the message device is off.
And another problem with this is in If statement it works only when i turn on the device.
And in while statement not but i need while because i need the display to give more text message i need the loop.
I know i use delay i am trying to use mills but i need to know hou i can blink a Neopixel.
But thats another task for me.
First i want to know how i get a clean solution for turn on and off device text message.
Please go easy on me this i am a noob,
The message off code:
while(decimal == 0){
  display.clearDisplay();
  u8g2_for_adafruit_gfx.setFont(u8g2_font_helvR14_tf);
  u8g2_for_adafruit_gfx.setCursor(25,30);
  u8g2_for_adafruit_gfx.print(F("Meetklok"));
  u8g2_for_adafruit_gfx.setCursor(20,50);
  u8g2_for_adafruit_gfx.print(F("aan zetten."));
  display.display();
  delay(2000);
  u8g2_for_adafruit_gfx.print(F("Druk op de"));
  u8g2_for_adafruit_gfx.print(F("groene knop."));
  display.display();
  delay(2000);
  strip.setPixelColor(0, 255, 0, 0);
  strip.show();
  strip.setPixelColor(0, 0, 0, 0);
  strip.show();
}//while
The hole code:
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <U8g2_for_Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
//define NeoPixel Pin and Number of LEDs
#define PIN 12
#define NUM_LEDS 1
//create a NeoPixel strip
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET    4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
U8G2_FOR_ADAFRUIT_GFX u8g2_for_adafruit_gfx;
//bar defines
#define MID_BAR_RESULT      1.85f                                                //mm Nominale maat
#define DELTA_BAR_RESULT    0.10f                                                //mm + en - vanuit het midden naar hoog en laag
#define MIN_BAR_RESULT      (MID_BAR_RESULT - DELTA_BAR_RESULT)                  //mm min scale reading (bar at bottom of rectangle)
#define MAX_BAR_RESULT      (MID_BAR_RESULT + DELTA_BAR_RESULT)                  //mm full scale reading (bar at top of rectangle)
#define MAX_BAR_Y           1                                                    //pixel Y # for bar max reading
#define MIN_BAR_Y           63                                                   //pixel Y # for bar min reading
#define BAR_Y_SPAN          (MIN_BAR_Y - MAX_BAR_Y)                              //pixel active Y span of rectangle
#define BAR_SCALE           ((float)BAR_Y_SPAN/(MAX_BAR_RESULT-MIN_BAR_RESULT))  //pixel/mm scale term
int req = 5; //mic REQ line goes to pin 5 through q1 (arduino high pulls request line low)
int dat = 6; //mic Data line goes to pin 2
int clk = 7; //mic Clock line goes to pin 3
int i = 0;
int j = 0;
int k = 0;
int signCh = 8;
int sign = 0;
int decimal = 0;
float dpp;
int units;
byte mydata[14];
String value_str;
long value_int; //was an int, could not measure over 32mm
float value;
uint8_t newBarY;
uint8_t lastBarY = MIN_BAR_Y;
  //pinMode (12, OUTPUT);
  strip.begin();
  strip.show();
  display.begin(SSD1306_SWITCHCAPVCC, 0x3D);
  u8g2_for_adafruit_gfx.begin(display);
  pinMode(req, OUTPUT);
  pinMode(clk, INPUT_PULLUP);
  pinMode(dat, INPUT_PULLUP);
  digitalWrite(req,LOW); // set request at high
  u8g2_for_adafruit_gfx.setForegroundColor(WHITE);
  u8g2_for_adafruit_gfx.setCursor(30,30);
  u8g2_for_adafruit_gfx.print(F("Laden..."));
  display.display();
// Neopixel collor test
  strip.show();
  strip.setPixelColor(0, 0, 255, 0);
  strip.show();
  strip.setPixelColor(0, 0, 0, 255);
  strip.show();
//Code device off.
  u8g2_for_adafruit_gfx.print(F("klok off"));
  display.display();
  delay(2000);
  u8g2_for_adafruit_gfx.print(F("Please turn on."));
  display.display();
  delay(2000);
//Indicate light
  strip.show();
  strip.show();
}//while
if ( (value <= 1.74) && (value > 0.05)){
  u8g2_for_adafruit_gfx.setCursor(35,20);
  u8g2_for_adafruit_gfx.print(F("Low"));
  display.display();
else if(value >= 1.96){
  u8g2_for_adafruit_gfx.print(F("High"));
  display.display();
else{
    display.setTextColor(WHITE);
    display.setTextSize(3);
    display.setCursor(15, 25);
    display.print(value,decimal);
    display.print("");
    if ( value <= MIN_BAR_RESULT )
     newBarY = MIN_BAR_Y;
    else if ( value >= MAX_BAR_RESULT )
      newBarY = MAX_BAR_Y;
      newBarY = (uint8_t)((MIN_BAR_Y - ((value - MIN_BAR_RESULT) * BAR_SCALE)) + 0.01);
    //Serial.print( "Measurement  \t" ); Serial.print(result); Serial.print( "\tY bar   \t" ); Serial.println( newBarY );
    //if( newBarY != lastBarY ) //would be used when clearDisplay not used
    display.drawRect( 0, 0, 7, 64, WHITE );// bar on the left
    display.drawLine(6, 32, 0, 32, WHITE);// bar on the left center line.
    //display.drawLine( 4, lastBarY, 0, lastBarY, BLACK );//would be used when clearDisplay not used
    display.drawFastHLine( 0, newBarY, 6, WHITE );
    DrawBar( newBarY );
    //lastBarY = newBarY; //would be used when clearDisplay not used
    //}//if
    display.display();
}//End if
digitalWrite(req, HIGH); // generate set request
for( i = 0; i < 13; i++ ) {
k = 0;
for (j = 0; j < 4; j++) {
while( digitalRead(clk) == LOW) {
} // hold until clock is high
while( digitalRead(clk) == HIGH) {
} // hold until clock is low
bitWrite(k, j, (digitalRead(dat) & 0x1));
mydata[i] = k;
sign = mydata[4];
value_str = String(mydata[5]) + String(mydata[6]) + String(mydata[7]) + String(mydata[8] + String(mydata[9] + String(mydata[10]))) ;
decimal = mydata[11];
units = mydata[12];
value_int = value_str.toInt();
if (decimal == 0) dpp = 1.0;
if (decimal == 1) dpp = 10.0;
if (decimal == 2) dpp = 100.0;
if (decimal == 3) dpp = 1000.0;
if (decimal == 4) dpp = 10000.0;
if (decimal == 5) dpp = 100000.0;
value = value_int / dpp;
delay(100);
//Drawbar
void DrawBar( uint8_t newBarY ){
  if ( newBarY == 32 )
    display.drawFastHLine( 0, newBarY, 5, WHITE );
    if ( newBarY < 32 )
      display.fillRect(1, newBarY, 6, 32 - newBarY, WHITE );
      display.fillRect(1, 32, 6, newBarY - 32, WHITE );
  }//else
}//DrawBar
I look at this line:   decimal = mydata[11];
What data is there in mydata when message device is off? Make a kind of analyse that gives the variable decimal a value when power is on. "All other conditions" are then handled as off.
Hi Railroader,
The data Is off 0 and when on 2.
Okey. I don't understand why You get stuck. When the measuring device is powered off data should be "special", abnormal... and that ought to be possible to detect.
Normally data is true or false, 0 or 1, but using like a third state, "not valid" ought to provide a solution.
I have found the code for the measuring device online.
And added things i wanted like info in display en led.
i am glade i made it so far.
I will look to and keep trying..
Good, but I don't like "found code". There's plenty of code being useless for You. You need to get knowing what the code is doing, how it works.
I suggest working backwards from "decimal = ... and find a place, a way, where You can take action, set a "power off flag" being used down in the code.
But, as long as You have hope and is optimistic it's good.
I am always trying t know what the code is doing.
But i am learning it, it will take a while but i keep on trying.
Good. People being ill often receives advice about exercises, change of habits etc. but don't follow it. People want it to be easy, a pill to swallow. Sometimes I feel that members want "some code", "a library", a miracle, just like the pil, instead of learning and working. Programming calls for sharp eyes, a sharp brain, hard work, brain work.
Personally I chased a real time error får a year, popping up from nowhere. I rebuilt large memory cards, changed software. One day, no in the middle of the night, lightning hit me. It was a microprocessor signal I skipped 3 ears earlier.
So... don't swap codes, like searching the magic pill. Penetrate the code You've got and learn more.
