How to know if someone lost or still on track with Google Maps Response?
So I have a project with GPS module and I want to search route with Google Maps. I have done implementing GPS with Google Maps, but now I come into a problem. I don't know if user still on track.
I get this array of steps from API Response:
 "steps" :
                     "distance" :
                        "text" : "50 m",
                        "value" : 50
                     "duration" :
                        "text" : "1 min",
                        "value" : 39
                     "end_location" :
                        "lat" : -7.282490199999999,
                        "lng" : 112.7951477
                     "html_instructions" : "Head \u003cb\u003esoutheast\u003c/b\u003e",
                     "polyline" :
                        "points" : "phmk@ufmoTr@o@JO"
                     "start_location" :
                        "lat" : -7.2821734,
                        "lng" : 112.7948261
                     "travel_mode" : "WALKING"
Above is the example of 1 steps. Currently, I take the latitude and longitude and using Harvine Formula to find the distance from the GPS to the end_location. I use this function to count distance:
// Count distance in meters
double getDistanceInM(double lat1, double lon1, double lat2, double lon2) {
    double R =  6335439; // Radius of the earth in m
    double dLat = deg2rad(lat2 - lat1);  // convert degrees to radians
    double dLon = deg2rad(lon2 - lon1);
    double a = sin(dLat/2) * sin(dLat/2) +
               cos(deg2rad(lat1)) * cos(deg2rad(lat2)) *
               sin(dLon/2) * sin(dLon/2);
    double c = 2 * atan2(sqrt(a), sqrt(1-a));
    double d = R * c; // Distance in m
    return d;
After that I wait till the distance is below 5m before I instruct a new route to the user.
But how to know if user walking in the intended route. What if the user miss a turn. How can I know this?
I thought about counting distance between this step end_location and next step end_location. I thought that user should be closer to this step end_location then next_step end location, but I don't think this is the right way to do it
assuming you have straight (great circle) path between two way points, what you need to track is known as XTE in GPS terminology ➜ the Cross Track Distance
see my post
➜ you'll know if you are left or right of the ideal path and have the distance to that path
Wow that's what I need. Thanks for the answer
