Hey, Its the first time so angry comments please
I got myself a fl-s401a flow rate sensor and I dont see in any place the flow rate.
I checked and it does about 26 rotations per second
I will be happy if someone can say to my solution
Here are the specs:
Frequency: F=98 * Q (L / Min), error: ± 2%
Flow range:0.3-6L/min
Suitable for 1/4" tube
Maximum Consumption current:10 mA(DC 5V)
Working voltage range:DC 5-18 V
Operating Temp:0-80 ℃
Operating humidity:35%-90%RH
Pressure range: 0-0.8MPa Storage Temperature:-25-80C
Storage humidity:25%-95%RH
Output Waveform:Square Wave,output pulse singal.
ROHS Compliant.
Cable length:15cm
Multiply? What is "it"? Show your work (the math)...how do you get Q from F=98*Q? And, what (approximate) flow rate are you expecting to be associated with 26 rotations/sec?
When I look for a fl-s401 the search returns a flame sensor, not a flow meter. That is why it is important to post links to technical information on all the hardware devices you use. At this point I cannot help.
PS: judging from comments on Amazon for a similar product, your Amazon/Banggood/whatever formula may be wrong, and you may have to do your own calibration...never a bad thing to do, BTW.
