How to limit serial data send?. Please help
Hi guys, I want to send data through Serial channel. But my data is sending as a rate faster than I need it. How can I limit it to like 4 times / second. I’m thinking about using timer for sending function. Code included. Any help is appreciated
Edit.ino (2.09 KB)
#include <MsTimer2.h>
#include <LIDARLite.h>
#include <AccelStepper.h>
#include <Servo.h>
#include <Wire.h>
#define HALFSTEP 8
#define FULLSTEP 4
#define blue 9
#define pink 10
#define yellow 11
#define orange 12
int distance;
int angleScan = 0;
int angleRotate = 0;
int targetPosition = 4096; // 4096 for 1 full circle
int roundCount=0;
bool clockwise = true;
AccelStepper stepper(8, 2, 4, 3, 5);
Servo servo;
LIDARLite myLidarLite;
//   MsTimer2::set(500, printOutput); // 250ms period
//   MsTimer2::start();
   servo.attach(8);
   stepper.setMaxSpeed(1000);
   myLidarLite.begin();
   //Moving to initial position
   stepper.moveTo(targetPosition);
   stepper.setSpeed(650);
   servo.write(angleScan);
  if (angleScan <=90)
    angleRotate=stepper.currentPosition()*360/4096;
    myLidarLite.beginContinuous(false,0x13,0xff,0x62);  //100Hz, infinite reading\
    distance = myLidarLite.distanceContinuous();
    if(distance>1300)
      distance-=1300;
      printOutput(angleRotate,angleScan,distance);
        if(stepper.distanceToGo()==0)
          roundCount++;
          stepper.setCurrentPosition(0);
          if (roundCount=1) // when system revolve 1 times, elevate the Lidar by 5
            roundCount=0;
            angleScan = (angleScan + 5);
  stepper.runSpeed();
void printOutput(int angleRotate, int angleScan, int distance)
  Serial.print("T");
  if (angleRotate < 10)
    Serial.print("00");
  else if (angleRotate < 100)
    Serial.print("0");
  Serial.print(angleRotate);
  Serial.print("P");
  if (angleScan < 10)
    Serial.print("00");
  else if (angleScan < 100)
    Serial.print("0");
  Serial.print(angleScan);
  Serial.print("V");
  if (distance < 10)
    Serial.print("000");
  else if (distance < 100)
    Serial.print("00");
  else if (distance < 1000)
    Serial.print("0");
  Serial.println(distance);
The following will allow the printing only every 250 milliseconds, no matter how often the printOutput function is called. Is that what you meant?
  static unsigned long timer = 0;
  unsigned long interval = 250;
  if (millis() - timer > interval)  // has a quarter second passed since last print?
    timer = millis();
    Serial.print("T");
      Serial.print("00");
      Serial.print("0");
    Serial.print("P");
    if (angleScan < 10)
      Serial.print("00");
      Serial.print("0");
    Serial.print("V");
    if (distance < 10)
      Serial.print("00");
      Serial.print("0");
Yes, thank you both ^^. I will check if it worked
