Hi, i am newbie.
I can link one gy-521(mpu6050) to arduino uno and run the Teapot demo.
I have a idea needs 6 mpu6050s.
Someone suggest me using mega2560 or stm32 instead.
Is this achievable using a uno?
Hi, i am newbie.
Hi, every one.
I made some advance.
Follow official trick,
I wired 2 GY-521s to UNO like:
2GY521s - UNO
INT - 2
TX/RX - A4/A5
VCC/GND - VCC/GND
1st GY521 AD0 - 9
2nd GY521 AD0 - 10
when I write code like:
digitalWrite(9, LOW);
digitalWrite(10, HIGH);
//data processing
or
digitalWrite(9, HIGH);
digitalWrite(10, LOW);
//data processing
the 2 GY-521s works well separately.
But when I change the code like:
//data processing
//data processing
The system wait INT for a long time (more than 5s),
After waiting, 2 GY-521s works for a while (also about 5s),
Then waiting for INT.
Why this happens?
I found 2 MPU6050s compete on INT0 and this result in FIFOoverflow
Is there any method transfering data without interrupt?
From what I can see, the 6050 has only 1 address bit, and it can have a I2C address of either 0x68 or 0x69 so that would limit you to having only 2 of them.
I have realized a solution with 2 6050s like:
2GY521s - UNO
TX/RX - A4/A5
VCC/GND - VCC/GND
1st GY521 AD0 - 9
2nd GY521 AD0 - 10
–NO INT linked–
The code
#include <Kalman.h>
#include <Wire.h>
#include <Math.h>
float fRad2Deg = 57.295779513f;
const int MPU = 0x68;
const int nValCnt = 7;
const int nCalibTimes = 50;
int calibData[nValCnt];
unsigned long nLastTime = 0;
float fLastRoll = 0.0f;
float fLastPitch = 0.0f;
Kalman kalmanRoll;
Kalman kalmanPitch;
int numOfMPU = 1;
Wire.begin();
pinMode( 9, OUTPUT);
pinMode(10, OUTPUT);
if (numOfMPU == 1)
numOfMPU = 2;
digitalWrite( 9, LOW);
numOfMPU = 1;
digitalWrite( 9, HIGH);
WriteMPUReg(0x6B, 0);
Calibration();
nLastTime = micros();
int readouts[nValCnt];
ReadAccGyr(readouts);
float realVals[7];
Rectify(readouts, realVals);
float fNorm = sqrt(realVals[0] * realVals[0] + realVals[1] * realVals[1] + realVals[2] * realVals[2]);
float fRoll = GetRoll(realVals, fNorm);
if (realVals[1] > 0) {
fRoll = -fRoll;
float fPitch = GetPitch(realVals, fNorm);
if (realVals[0] < 0) {
fPitch = -fPitch;
unsigned long nCurTime = micros();
float dt = (double)(nCurTime - nLastTime) / 1000000.0;
float fNewRoll = kalmanRoll.getAngle(fRoll, realVals[4], dt);
float fNewPitch = kalmanPitch.getAngle(fPitch, realVals[5], dt);
float fRollRate = (fNewRoll - fLastRoll) / dt;
float fPitchRate = (fNewPitch - fLastPitch) / dt;
fLastRoll = fNewRoll;
fLastPitch = fNewPitch;
nLastTime = nCurTime;
//Serial.print(“Roll:”);
//Serial.print(fNewRoll);
//Serial.print(’(’);
Serial.println(fRollRate);
//Serial.print("),\t\tPitch:");
//Serial.print(fNewPitch);
//Serial.print(fPitchRate);
//Serial.print(")\n");
delay(10);
void WriteMPUReg(int nReg, unsigned char nVal) {
Wire.beginTransmission(MPU);
Wire.write(nReg);
Wire.write(nVal);
Wire.endTransmission(true);
unsigned char ReadMPUReg(int nReg) {
Wire.write(nReg);
Wire.requestFrom(MPU, 1, true);
return Wire.read();
void ReadAccGyr(int *pVals) {
Wire.write(0x3B);
Wire.requestFrom(MPU, nValCnt * 2, true);
for (long i = 0; i < nValCnt; ++i) {
pVals = Wire.read() << 8 | Wire.read();
Yes, the 6050 may have only one address bit. Drive each device with a unique data line from the Arduino to the address line.
Hold the line High for all of them, which is address 0x69 I think. Drive one low and talk to address 0x68 - the one device with its address line low will be the one you are accessing.
That's right, I have just used this trick.
i have tested 3 sensors,
it works well.
