Hello, long time software dev here new to Arduino.
Using an Uno with a SIMCOM7600 for connectivity, MQTT and SSL. But I need to load the SSL certs onto the SIMCOM, about 4.4k in size total.
How do I load them? I'm trying it via the IDE Serial Monitor or minicom, only I suspect they're getting corrupted on the way in due to the Soft Serial port, pins 7/8. On the minicom I can hear audible beeps when I paste the files in, suggesting overflow.
So, I went about hard coding the certs into a sketch, only the compiler gripes that it's too much data:
"Sketch uses 12770 bytes (39%) of program storage space. Maximum is 32256 bytes. Global variables use 5079 bytes (247%) of dynamic memory, leaving -3031 bytes for local variables. Maximum is 2048 bytes."
So I'm wondering if there is some other way to load these onto the Arduino, then I can have code that s-l-o-w-l-y copies it onto the SIMCOM i.e send a few bytes, delay(N), repeat...
The other thing I can try is to write a script that will copy them of the /dev/cu.usbmodem134, if I have to.
How are people doing this?
Thanks
Mike
PS I'm using the standard code for monitoring i.e.
while(1){
while (modem.available()) {
Serial.write(modem.read());
while(Serial.available()) {
modem.write(Serial.read());
