How to loop a custom function
Im trying to make a custom controller for my LED strip and i need help with looping the custom pallets
located in "void loop"
#include <ezButton.h>
#include <FastLED.h>
#define NUM_LEDS 100
#define DATA_PIN 3
#define BRIGHTNESS 100
ezButton Pallet_1 (8);
ezButton Pallet_2 (9);
ezButton Pallet_3 (10);
CRGB leds[NUM_LEDS];
  Pallet_1.setDebounceTime(50);
  Pallet_2.setDebounceTime(50);
  Pallet_3.setDebounceTime(50);
  FastLED.addLeds<WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS);  // GRB ordering is typical
  FastLED.setBrightness(BRIGHTNESS);
    leds[0] = CRGB::Black;
  FastLED.show();
 Pallet_1.loop();
 Pallet_2.loop();
 Pallet_3.loop();
 int Pallet_1State = Pallet_1.getState();
 int Pallet_2State = Pallet_2.getState();
 int Pallet_3State = Pallet_3.getState();
 if(Pallet_1.isPressed())Pallet1();
 if(Pallet_2.isPressed())Pallet2();
 if(Pallet_3.isPressed())Pallet3();
void fadeall() { for(int i = 0; i < NUM_LEDS; i++) { leds[i].nscale8(250); } }
void Pallet1() {
 static uint8_t hue = 0;
    leds[i] = CHSV(hue++, 255, 255);
    FastLED.show();
    fadeall();
    delay(10);
  for(int i = (NUM_LEDS)-1; i >= 0; i--) {
    FastLED.show();
    fadeall();
    delay(10);
void Pallet2() {
  leds[0] = CRGB::Green;
  FastLED.show();
void Pallet3() {
  leds[0] = CRGB::Blue;
  FastLED.show();
What do You want us to help You with?
Well done using autoformat and code tags!
That code looks okey to me.
Could you restate what it is that you want? Could you describe what the code currently does? Could you describe what you'd like the code to do?
+1 for using code tags.
ok so located in the main loop you have
which detects when the button is pressed and plays the pallet's ive set up but it only plays it once
i want it to loop till you press another button selecting another pallet which will then loop again till you press another pallet
hope that makes sense
pondering... if you want it to be in states that are independent of the current button state, you need a variable to remember that. Then you set the variable with the buttons, act on the variable independently. The variable would indicate one of 4 states, pallet_1, pallet_2, pallet_3, or none.
so i did what u said and did
 int Pallet = 0;
 if(Pallet_1.isPressed())int Pallet = 1;
 if(Pallet_2.isPressed())int Pallet = 2;
 if(Pallet_3.isPressed())int Pallet = 3;
 if (Pallet = 1;)Pallet1();
 if (Pallet = 2;)Pallet2();
 if (Pallet = 3;)Pallet3(); <<<<<<<<<<<
but i keep getting the error
"expected primary-expression before ')' token"
(marked the line with) <<
perhaps you can spot the extra ;?
In this code you should remove all of the int.
Pallet = 1 is an assignment NOT a test. Pallet == 1 is a test.
I think what you mean is this:
 if (Pallet == 1) Pallet1();
 if (Pallet == 2) Pallet2();
 if (Pallet == 3) Pallet3();
is different from
Pallet == 1
Instead of:
you could write:
switch(Pallet)
  case 1:
    Pallet1();
  case 2:
    Pallet2();
  case 3:
    Pallet3();
Hello
Maybe try something like this
  static ezButton * pallet = nullptr;
  if(Pallet_1.isPressed()) pallet = &Pallet_1;
  if(Pallet_2.isPressed()) pallet = &Pallet_2;
  if(Pallet_3.isPressed()) pallet = &Pallet_3;
  Pallet( pallet );
void Pallet( ezButton * pallet )
  if ( pallet == &Pallet_1 )
      FastLED.show();
      fadeall();
      delay(10);
      FastLED.show();
      fadeall();
      delay(10);
  else if ( pallet == &Pallet_2 )
    FastLED.show();
  else if ( pallet == &Pallet_3 )
    FastLED.show();
yeah sorry i just noticed it :grinning_face_with_smiling_eyes:
@ guix
Unnecessary high level to use for a member not being highly experienced.
