Hello guys! got a new LCD module. i am using the liquid display sketch from the arduino. However i cannot get more than 16 digits in a row. what i want is for the text to go to the second row.
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup(){
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// initialize the serial communications:
// when characters arrive over the serial port...
if (Serial.available()) {
// wait a bit for the entire message to arrive
delay(100);
// clear the screen
lcd.clear();
// read all the available characters
while (Serial.available() > 0) {
// display each character to the LCD
lcd.write(Serial.read());
anyone knows how to make the excess text to the second row? thanks!
You should count the characters and when you reach 16 jump to the second line
delay(100);
// clear the screen
lcd.clear();
int nbchars=0;
while (Serial.available() && i<16) {
nbchars++;
lcd.setCursor(0, 1);
while (Serial.available()) {
// display remaining characters on the second line
hey thanks for the reply, will work on it with your help =) happy easter!
desmondttm123:
I think yopu are looking for the cursor commands. In the code below, a reading is put at the start of the first row (0) and then chr 11, then the same at start and chr 11 on the second row.
lcd.setCursor (0,0);
lcd.print(InTemp);
lcd.setCursor (11,0);
lcd.print (OutTemp);
lcd.setCursor(0,1);
lcd.print(diff);
lcd.print(" ");
lcd.setCursor(11,1);
lcd.print(DrainTemp);
hello, do i add the command in void loop? because it cant compile
Yes. It is just a snippet and certainly won't compile by itself. It was just intended to show how the cursor command works but, if you put your own variables in, it should give you a display.
