how to make a Boebot controlled by arduino uno get out of a maze?
I am trying to get my arduino uno Boebot to get out of a Maze but am unable here is my code if you have any idea or code plz message me.
(Code tags added by Moderator)
#include <Servo.h>
Servo left;
Servo right;
Servo sensor;
float val = 0;
float vald = 0;
float valc = 0;
float valg = 0;
float dist=0;
float distd=0;
float distc=0;
float  distg=0;
left.attach(9);   //pin
right.attach(8);   //pin
sensor.attach(10);
 sensor.write(85);//le mettre a l'avant
    left.write(2000);
  right.write(1000);
    sonar();
  val = pulseIn(11,HIGH);
  dist= val/2/29 ;
        Serial.println ("dist");
        Serial.println (dist);
         Serial.println ("VAL");
        Serial.println (val);
      if(dist <13 && dist > 0)
          //tourne 180
            right.write(2000);
            left.write(2000);    //2000 ou 1000
            delay(1100); //2fois le delay de 90 degres
          //arret
          right.write(1500);
          left.write(1500);         delay(1000);
        //capteur droit
           sright();
            sonar();
              vald = pulseIn(11,HIGH);
              distd= vald/2/29 ;
         //capteur centre
           scenter();  //le mettre a l'avant
            sonar();
              valc = pulseIn(11,HIGH);
              distc= valc/2/29 ;
         //capteur gauche
          sgauche();  //le mettre gauche
            sonar();
              valg = pulseIn(11,HIGH);
              distg= valg/2/29 ;
        Serial.println ("distc");
        Serial.println (distc);
        Serial.println ("distd");
        Serial.println (distd);
        Serial.println ("distg");
        Serial.println (distg);
             if (distd>13||distg>13)
                      if(distd>distc&&distd>distg)
                          {//90 droite
                             tournedroite();
                      if(distg>distc&&distg>distd)
                          {//90 a gauche
                            tournegauche();
           {//devant
              sensor.write(70);//le mettre a l'avant
               avance();
            right.write(1000);   //1000 ou 2000
void sonar()
        pinMode(11,OUTPUT);
      digitalWrite(11,HIGH);
      delayMicroseconds(5);
      digitalWrite(11,LOW);
        pinMode(11,INPUT);
void sgauche()
  sensor.write(170);
void scenter()
  sensor.write(85);
void sright ()
  sensor.write(0);
void avance()
  left.write(2000);
  right.write(1000);
void tournedroite()
  left.write(2000);
  right.write(1500);
  delay(1100);
void recule()
  left.write(1000);
  right.write(2000);
void tournegauche()
  left.write(1500);
  right.write(1000);
  delay(1100);
I don't think I got the memo that smiley faces could be used as pins. Could you put your code in code tags. Its the # symbol above the smiley faces.[ code ] ... [/ code]
I also see a lot of delays, no no no. Not good for your code.
