How to make a call which number is stored in EEPROM when a switched is pressed
I watched SIM800l tutorials, I am able to register 5 phone numbers by watching some videos. But can you please tell me how can I make a call to admin number which is stored in EEPROM when a switch is pressed. It works for the first time but if I turn off the arduino power supply it doesn't work. Please suggest me. Thanks in advance. I am using this code:
#include <SoftwareSerial.h>
#include <EEPROM.h>
const int totalPhoneNo = 2;
String phoneNo[totalPhoneNo] = {"",""};
int offsetPhone[totalPhoneNo] = {0,13};
String tempPhone = "";
//GSM Module RX pin to Arduino 8
//GSM Module TX pin to Arduino 7
#define rxPin 7
#define txPin 8
#define Alarm 4
#define Relay 3
#define Switch 5
SoftwareSerial sim800(rxPin,txPin);
String smsStatus,senderNumber,receivedDate,msg;
boolean isReply = false;
boolean DEBUG_MODE = 1;
  Serial.println("Arduino serial initialize");
  sim800.begin(9600);
  Serial.println("SIM800L software serial initialize");
  smsStatus = "";
  senderNumber="";
  receivedDate="";
  msg="";
  Serial.println("List of Registered Phone Numbers");
  for (int i = 0; i < totalPhoneNo; i++){
    phoneNo[i] = readFromEEPROM(offsetPhone[i]);
    if(phoneNo[i].length() != 14)
      {phoneNo[i] = "";Serial.println(String(i+1)+": empty");}
      {Serial.println(String(i+1)+": "+phoneNo[i]);}
  delay(2000);
  sim800.print("AT+CMGF=1\r"); //SMS text mode
  //delete all sms
  sim800.println("AT+CMGD=1,4");
  sim800.println("AT+CMGDA= \"DEL ALL\"");
  pinMode(Alarm, OUTPUT);
  pinMode(Relay, OUTPUT);
  pinMode(Switch, INPUT);
  digitalWrite(Switch, HIGH);
  digitalWrite(Relay, LOW);
while(sim800.available()){
  parseData(sim800.readString());
while(Serial.available())  {
  sim800.println(Serial.readString());
if(digitalRead(Switch) == LOW){ //if(digitalRead(Switch) == LOW)
  sim800.println("ATD"+phoneNo[0]+";"); //senderNumber
  Serial.println("Calling...");
  delay(7000);
  digitalWrite(Alarm, HIGH);
  Serial.println("Alarm Turned ON");
  digitalWrite(Relay, HIGH);
  Serial.println("Relay Turned ON");
} //main loop ends
void parseData(String buff){
  Serial.println(buff);
  unsigned int len, index;
  //Remove sent "AT Command" from the response string.
  index = buff.indexOf("\r");
  buff.remove(0, index+2);
  buff.trim();
  if(buff != "OK"){
    index = buff.indexOf(":");
    String cmd = buff.substring(0, index);
    cmd.trim();
    if(cmd == "+CMTI"){
      //get newly arrived memory location and store it in temp
      index = buff.indexOf(",");
      String temp = buff.substring(index+1, buff.length());
      temp = "AT+CMGR=" + temp + "\r";
      //get the message stored at memory location "temp"
      sim800.println(temp);
    else if(cmd == "+CMGR"){
      extractSms(buff);
      if(msg.equals("r") && phoneNo[0].length() != 14) {
        writeToEEPROM(offsetPhone[0],senderNumber);
        phoneNo[0] = senderNumber;
        String text = "Number is Registered: ";
        text = text + senderNumber;
        debugPrint(text);
        Reply("Number is Registered", senderNumber);
      if(comparePhone(senderNumber)){
        doAction(senderNumber);
        //delete all sms
  else{
  //The result of AT Command is "OK"
void extractSms(String buff){
   unsigned int index;
    smsStatus = buff.substring(1, index-1);
    senderNumber = buff.substring(3, 14);
    buff.remove(0,19);
    receivedDate = buff.substring(0, 20);
    buff.remove(0,buff.indexOf("\r"));
    buff.trim();
    index =buff.indexOf("\n\r");
    buff = buff.substring(0, index);
    buff.trim();
    msg = buff;
    buff = "";
    msg.toLowerCase();
    String tempcmd = msg.substring(0, 3);
    if(tempcmd.equals("r1=") || tempcmd.equals("r2=")){
        tempPhone = msg.substring(3, 16);
        msg = tempcmd;
        //debugPrint(msg);
        //debugPrint(tempPhone);
void doAction(String phoneNumber){
  if(msg == "r2="){
    writeToEEPROM(offsetPhone[1],tempPhone);
    phoneNo[1] = tempPhone;
    String text = "Phone2 is Registered: ";
    text = text + tempPhone;
    debugPrint(text);
    Reply(text, phoneNumber); //phoneNumber
  else if(msg == "list"){
      String text = "";
      if(phoneNo[0])
        text = text + phoneNo[0]+"\r\n";
      debugPrint("List of Registered Phone Numbers: \r\n"+text);
  if(msg == "del=all"){
      writeToEEPROM(offsetPhone[0],"");
      phoneNo[0] = "";
      debugPrint("All phone numbers are deleted.");
      Reply("All phone numbers are deleted.", phoneNumber);
  smsStatus = "";
  senderNumber="";
  receivedDate="";
  msg="";
  tempPhone = "";
void Reply(String text, String Phone)
    sim800.print("AT+CMGS=\""+Phone+"\"\r");
    sim800.print(text);
    delay(100);
    sim800.write(0x1A); //ascii code for ctrl-26 //sim800.println((char)26); //ascii code for ctrl-26
    Serial.println("SMS Sent Successfully.");
void writeToEEPROM(int addrOffset, const String &strToWrite)
  byte len = 13;
  strToWrite.length();
  EEPROM.write(addrOffset, len);
  for (int i = 0; i < len; i++)
    EEPROM.write(addrOffset + i, strToWrite[i]);
String readFromEEPROM(int addrOffset){
  int len = 13;
  char data[len + 1];
    data[i] = EEPROM.read(addrOffset + i);
  data[len] = '\0';
  return String(data);
boolean comparePhone(String number){
  boolean flag = 0;
    if(phoneNo[i].equals(number)){
      flag = 1;
  return flag;
 void debugPrint(String text){
  if(DEBUG_MODE == 1)
    Serial.println(text);
