hello ,
I want to make a code that light a led when I press a button and also every 5 min.
I know how to do everyone by it self - but how do I combine then together?
also when I press the button the countdown will start from zero again?
thanks,
hello ,
thanks,
If you have some code, post it. If not, I'll ask that this be moved to the Project Guidance section.
david1234:
hello ,
How long do you want the LED lit?
Is that what you want to happen, or is that what you don't want to happen?
Post your code.
this is what I have so far :
int led = 13;
int test=4;
int timer=0;
pinMode(test,INPUT);
pinMode(led, OUTPUT);
{//start of loop
if (test==HIGH)
{//start of manual
Serial.println("button is on");
digitalWrite(led,HIGH);
delay(25000);
digitalWrite(led,LOW);
timer=0;
}//end of manual
else (timer<300000); //time of 5 min
timer++;//counting 5 min
}//end of counting
if (timer==300000)//5 min is past
{//start of auto blink
Serial.println ("now working auto");
delay(25000);
timer=0;
}//end of auto blink
}//end of the loop
int led = 13;
int test=4;
unsigned long timer=0; //int
[b]On the Arduino Uno (and other ATMega based boards)
an int stores a 16-bit (2-byte) value.
This yields a range of -32,768 to 32,767
(minimum value of -2^15 and a maximum value of (2^15) - 1). [/b]
{//start of loop
if (digitalRead(test) == HIGH) // test is the pin number, you need to read it
{//start of manual
delay(25000);
timer=0;
}//end of manual
else (timer<300000L); //time of 5 min
}//end of counting
if (timer==300000L)//5 min is past
delay(25000);
timer=0;
}//end of the loop
david1234:
this is what I have so far :else (timer<300000); //time of 5 min
This will increment timer for each iteration of loop(), not each millisecond.
As each iteration takes only microseconds, the count will reach 300000 long before 5 mins is up.
Look up 'blink without delay' in the Playground for an answer to your problem.
O.K
I saw it , but I think something is missing :
const int ledPin = 13; // the number of the LED pin
const int test=12;
int ledState = LOW; // ledState used to set the LED
long previousMillis = 0; // will store last time LED was updated
long interval = 600000; // interval at which to blink (milliseconds~~ 10 min)
pinMode(ledPin, OUTPUT);
{// start of loop
if(currentMillis - previousMillis < interval) { //What to do if didn't pass 10 min
{//start of manual
delay(25000);
}//end of wait
else // 10 min is done , need to light led auto
delay(25000);
}// end of loop
Is my logic correct ?
No.
By declaring the variable currentMillis at the start of every loop you reset it. Therefore you will never see it time out.
david1234:
O.K
Quite a lot!
Try this (untested):
const int test=12;
long startTime; // to store the start of the timer
Serial.begin(9600); //You need this for the serial monitor to work!
startTime = millis(); //set startTime
void loop(){// start of loop
if(millis() - startTime < interval) { //What to do if didn't pass 10 min
if (digitalRead(test) == HIGH) {//start of manual
digitalWrite(ledpin,HIGH);
delay(25000);
digitalWrite(ledpin,LOW);
startTime = millis(); //reset startTime
else { // 10 min is done , need to light led auto
delay(25000);
}// end of loop
it's work just fine!
Thank you very much.
