how to make a flasher to the led during the motor is running
AT line 94 in the code i want to make a flasher to the led during the motor is running at opening condition , please can i get a help ?!
limiitswitchtest22.ino (5.95 KB)
This loop is executing while your motor is running:
      while (digitalRead(limswitch) == LOW);  // Wait for limit switch to trigger (may need HIGH instead of LOW)
You can put the "BlinkWithoutDelay" blink code in the loop:
      while (digitalRead(limswitch) == LOW) {  // Wait for limit switch to trigger (may need HIGH instead of LOW)
  // From the BlinkWithoutDelay example
  if(currentMillis - previousMillis >= interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    ledState = !ledState;
    digitalWrite(ledPin, ledState);
