How to make a led blink 5 times and stop?
I'm a newbie and trying to find a way to make a light blink a set amount of time and then stop? So far all I can find is making a light blink using a loop.
Thank you
Show use what you have tried.
Take a look at some example of control statements.
Such as IF or FOR
Thank you. I will give it a go and post what I came up with.
so, it is a good opportunity to learn about functions:
try this:
int ledPin = 13;
int blinkTime = 500;
  pinMode(ledPin, OUTPUT);
  blinkyBlinky(5, blinkTime); // 5 is number of blinks, blinkTime is the milliseconds in each state from above: int blinkTime = 500;
void blinkyBlinky(int repeats, int time)
  for (int i = 0; i < repeats; i++)
    digitalWrite(ledPin, HIGH);
    delay(time);
    digitalWrite(ledPin, LOW);
    delay(time);
BulldogLowel is on the right line.
I would suggest a slight modification.
int ledPin = 13;
bool eyesStinging=true;
if(eyesStinging)                         //Only blink if it's absolutely necessary
    delay(time);
    delay(time);
I have tried this program just from the example of the BLINK program just made a little change.
I have tried this in #inbulit-led and #external-led also. You can see this code below and while
testing with external you should check the pins and declare them properly
blink5.ino (474 Bytes)
ganapati97:
