How to make a line foloower robot that goes back and forth the same line
Hello,
i managed to make a 4x4w robot to follow a line using L298N driver and IR modules. i want the robot to follow a line and then comes back following the same line, so i used four IR modules; two on the robot front, two on the back.
but my problem is that i could not write a proper code to do this, after trying so many times, i came here needing some guidance.
this sketch is for following a line but the robot does not come back, i would like to know what to add to this sketch to do what i want/
thank you.
    int motorA_E1 = 9;
    int motorA_E2 = 10;
    int motorA_speed = 5;
    int motorB_E3 = 11;
    int motorB_E4 = 12;
    int motorB_speed= 6;
    int left_sensor_pin = 2;
    int right_sensor_pin = 3;
  pinMode(motorA_E1, OUTPUT);
  pinMode(motorA_E2, OUTPUT);
  pinMode(motorB_E3, OUTPUT);
  pinMode(motorB_E4, OUTPUT);
  pinMode(motorA_speed, OUTPUT);
  pinMode(motorB_speed, OUTPUT);
  pinMode(left_sensor_pin, INPUT);
  pinMode(right_sensor_pin, INPUT);
    boolean left_sensor_state=digitalRead(left_sensor_pin);
    boolean right_sensor_state=digitalRead(right_sensor_pin);
if (left_sensor_state==0 and right_sensor_state==0)
    analogWrite (motorA_speed,120);
    analogWrite (motorB_speed,120);
     forward();
   else if (left_sensor_state==1 and right_sensor_state==0)
     analogWrite (motorA_speed,180);
     analogWrite (motorB_speed,180);
     turnLeft();
      else if (left_sensor_state==0 and right_sensor_state==1)
    turnRight();
   else if (left_sensor_state==1 and right_sensor_state==1)
       analogWrite (motorA_speed,0);
       analogWrite (motorB_speed,0);
     off();
void forward(){
    digitalWrite(motorA_E1,HIGH);
    digitalWrite (motorA_E2,LOW);
    digitalWrite(motorB_E3,LOW);
    digitalWrite (motorB_E4,HIGH);
void off() {
   digitalWrite(motorA_E1,LOW);
    digitalWrite (motorB_E4,LOW);
void turnRight(){
    digitalWrite(motorB_E3,HIGH);
void turnLeft() {
    digitalWrite (motorA_E2,HIGH);
Somehow the robot must "know" when to backtrack. How do You make that?
I suggest You make the robot turn around 180 degrees and use the same code for going back.
