How to make a PWM signal that changes frequency
Hi…
I am currently seeking for a simple method that creates a PWM signal, and changes the frequency such that it follows the positive slope of this figure.
The x-axis is there the time in seconds and y is the frequency in
I am currently creating the PWM signal by toggling a pin as such
 while(!(PINB & (1 << 2)))
      PORTB ^= _BV(PB3);  // Toggles the step_pin
But cannot change the frequency of the pin… How do i make it follow the positive slope of the curve?
You might find this library helpful
Could not be done in this while loop? like calculating a delay and decrementing that?
kidi3:
If you explain why you need to do this I think you will get more useful advice.
...R
You want to adjust both the frequency and the duty cycle (which appears to be 50% at the moment, if I read your code correctly ) ?
The graph does not appear to be linear between 0 and about 500 Hz. Is that intentional ?
