It is so hot! I am surprised to find that my beers are gone! To avoid this situation happens again, I decided to DIY a private safe to keep my drinks.
Come on! Chocho shows an ultimate skill now~
Hardware in need:
FireBeetle ESP32 board ร1
FireBeetle Covers-Gravity I/O Expansion Shield ร1
Gravity: Digital Push Button ร1
3-Wire LED Module 8 Digital (Arduino Compatible) ร1
Rotary Encoder ร1
Crash sensor ร1
9g micro servo ร1
Dupont wires
Cardboard
*Click here to download software code in need.
Operating process
- Make mounting location of digital push button, numerating tube and rotary encoder.
Find a cardboard (about30cmร20cm) and make a space according to the numerating tube, shown as below.
Tip1: Marking first and cut with a small knife, a tape can help you keep the right direction.
The cutting result is as below:
2. Keep digital push button, numerating tube and rotary encoder.
Keep all modules with hot melt adhesive.
Please put another pad when fix the rotary encoder.
3. Make a latch.
Put a cardboard (about 10cmร3cm) which function as a latch between two small cardboards and fix it to the โdoorโ. The latch is moveable.
Then fix another cardboard to these cardboards to stable the latch.
- Install the micro servo.
The micro servo controls the latch, pulls to open the door or close it.
A stretched spring connects servo to latch.
The spring connects to latch at one end and to servo at the other end.
Then, fix the servo to the door appropriately, shown as below.
Fix the crash sensor.
Install the crash sensor above the latch to check whether the door is closed. Once the door is closed, the latch will slip to the right (to close the safe). -
Fix the FireBeetle ESP32
Fix the board to the lower left of door and plug in Gravity I/O Expansion Shield.
Connect control wires.
There is no circuit diagram, no need for soldering here, you can connect with dupont wires directly.
Order of connection is as below:
For rotary encoder:
A to D0
B to D1
C to D7
For numerating tube:
LatchPin to D2
ClockPin to D3
DataPin to D4
Micro servo to D6
Digital push button to D9
Crash sensor to D8
Add a small box to the door.
To make the door more beautiful, we need to put a box to hide wheels. Cut 4 cardboards of 5cm height to cover the electronic components.
Letโs make a cardboard lid!
Install door to the safe.
Firstly, make a window in the safe to install the door.
Secondly, fix a small cardboard to the safe at one end and to the door at the other end as a moveable curtain.
