What a hot day it is! Too hot to drive and ride and I am thinking of making a temperature measurement sensor. With FireBeetle ESP32 produced by DFRobot and MLX90614 (a noncontact IR temperature sensor) on hand, let’s do it!
Make an Infrared Thermometer Gun using FireBeetle EPS32-YouTube
Hardware &software in need
FireBeetle ESP32, the new master board produced by DFRobot, smaller than traditional Arduino Uno, with build-in power port and charging circuit, it is ideally suitable for making low-power-consumption devices.
MLX90614, compared to traditional LM35, DS18B20 temperature sensors, it is a noncontact IR temperature sensor uses infrared radiation to measure the temperature and does not require direct touch. With IIC interface, it is very convenient to contact to master board.
Gravity IIC OLED-2864 display, a very beautiful self-luminous display module with a blue background. The display bezel is constructed form aluminum alloy that protects the screen from scratches and damage.
uPyCraft MicroPython IDE, programing with python and decreases development difficulty.
Hardware in need
Hardware List
FireBeetle ESP32 IOT Microcontroller ×1
Gravity: Non-contact IR Temperature Sensor for Arduino ×1
Gravity I2C OLED-2864 Display ×1
3.7V 400mAh Lithium battery ×1
Red laser transmitter (diameter: 6mm) ×1
C&K slide switch ×1
3D printing crust set (2 parts) ×1
Tools
Thermo-control Anti-Static Soldering Station AT936b
Overlord Pro 3D printer
401 glue
Hot melt gun
Software list
MLX90614.py (library file of MLX90614 noncontact IR temperature sensor)
SSD1306.py (library file of Gravity IIC OLED-2864 display)
piclib.py (library file of show pictures and 16*24 script used in the project)
InfraRedThermometer.py (source files of project codes)
PCtoLCD2002 LCD impression taking software
3D printing slice software: Cura
3D printing file: 3D print - left part.stl (available for direct printing of Overload Pro 3D printer)
3D printing file: 3D print - right part.stl
Operating process
- Solder components as below:
Connection diagram
- Transform show pictures and 16*24 script in use to hexadecimal code with PCtoLCD2002 LCD impression taking software
Setting and take impression as below:
Programing with uPyCraft MicroPython IDE and burn codes to FireBeetle ESP32.
Check after codes burnt. -
Designing crusts according to dimension of components.
Use Cura (a 3D printing slice software) to make 3D printing files.
Print crusts with Overload Pro 3D printer.
Allocate components to inner part of printed crusts with hot melt and glue.
Temperature measurement
Measure temperature of palm
Measure temperature of mobike saddle
Now, we have accomplished the procedure of practical noncontact temperature measurement gun. You can modify this program according to effective demands. For example, you can upload results to Internet of Things or cellphones with Wi-Fi and BLE Bluetooth in FireBeetle ESP32. I am always cannot recollect whether I have turned off gas cooker when I got out, so a noncontact temperature measurement gun that can upload data to IoT or phone is very helps me a lot.
