How to make a " Water Filling Machine "?
Hello a Newbie here,
I am working on a project name "Water Filling Machine".
In this i am facing a problem related to the code....
(Currently i don't have any code, I need a code).
I wanted to make a machine, In which i can input a value like if i put value 500ml using keypad the machine should dispense only 500ml in the jar or if i put value 1 liter then it should dispense only 1 liter only...And if i put the jar in front of dispenser the dispenser should dispense the water......
Parts that i have
Arduino Uno
16*2 LCD / i2c
Flow rate sensor
ir sensor
pump
keypad
breadboard/jumper wires...etc
The point is " I need a code for this "
and if i get the code then i will do connection as per the code
(you need not to worry about the connections) ...
So in other words You want that someone make coding or project for you?
Chill out bro,
I meant to say that i just need the code...As i am very new to arduino programming...
As i get the code, I will make the connection and part needed as per the code...
Sorry to correct you, but by seeing the code you can just setup the connection...Or you can do connection first then coding part...Its your wish...but it doesn't matter...
This bro is real chill but still the question remains, you want someone to just write code for you and you'll make all the necessary connections right? Who will debug the code and test the code to make sure it does what you want?
All right, I'll bite. Here is some code that runs a pump to move some water around.
As a demonstration of your ability to connect things based upon the code, here you go:
#include <ESP32Time.h>
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h" // include the connection info for WiFi and MQTT
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include <driver/adc.h>
#include <SimpleKalmanFilter.h>
WiFiClient      wifiClient; // do the WiFi instantiation thing
PubSubClient    MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
ESP32Time       rtc;
#define evtDoParticleRead  ( 1 << 0 ) // declare an event
#define evtADCreading      ( 1 << 3 )
EventGroupHandle_t eg; // variable for the event group handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
QueueHandle_t xQ_RemainingMoistureMQTT;
QueueHandle_t xQ_RM;
QueueHandle_t xQ_Message;
struct stu_message
  char payload [150] = {'\0'};
  String topic;
} x_message;
int    mqttOK = 0;
bool   TimeSet = false;
bool   manualPumpOn = false;
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  // clear locations
  memset( x_message.payload, '\0', 150 );
  x_message.topic = ""; //clear string buffer
  x_message.topic = topic;
  int i = 0;
  for ( i; i < length; i++)
    x_message.payload[i] = ((char)payload[i]);
  x_message.payload[i] = '\0';
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
  x_message.topic.reserve(150);
  xQ_Message = xQueueCreate( 1, sizeof(stu_message) );
  xQ_RemainingMoistureMQTT = xQueueCreate( 1, sizeof(float) ); // sends a queue copy
  xQ_RM = xQueueCreate( 1, sizeof(float) );
  eg = xEventGroupCreate(); // get an event group handle
  sema_mqttOK =  xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  gpio_config_t io_cfg = {}; // initialize the gpio configuration structure
  io_cfg.mode = GPIO_MODE_INPUT; // set gpio mode. GPIO_NUM_0 input from water level sensor
  io_cfg.pull_down_en = GPIO_PULLDOWN_ENABLE; // enable pull down
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_0) ); //bit mask of the pins to set, assign gpio number to be configured
  gpio_config(&io_cfg); // configure the gpio based upon the parameters as set in the configuration structure
  io_cfg = {}; //set configuration structure back to default values
  io_cfg.mode = GPIO_MODE_OUTPUT;
  io_cfg.pin_bit_mask = ( 1ULL << GPIO_NUM_4 | (1ULL << GPIO_NUM_5) ); //bit mask of the pins to set, assign gpio number to be configured
  gpio_set_level( GPIO_NUM_4, LOW); // deenergize relay module
  gpio_set_level( GPIO_NUM_5, LOW); // deenergize valve
  // set up A:D channels  https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
  adc1_config_width(ADC_WIDTH_12Bit);
  adc1_config_channel_atten(ADC1_CHANNEL_3, ADC_ATTEN_DB_11);// using GPIO 39
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 10000, NULL, 6, NULL, 1 );
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 10000, NULL, 5, NULL, 1 ); // assign all to core 1, WiFi in use.
  xTaskCreatePinnedToCore( fPublish, "fPublish", 9000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fReadAD, "fReadAD", 9000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fDoMoistureDetector, "fDoMoistureDetector", 70000, NULL, 4, NULL, 1 );
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 2, NULL, 1 );
} //void setup()
void fReadAD( void * parameter )
  float    ADbits = 4096.0f;
  float    uPvolts = 3.3f;
  float    adcValue_b = 0.0f; //plant in yellow pot
  uint64_t TimePastKalman  = esp_timer_get_time(); // used by the Kalman filter UpdateProcessNoise, time since last kalman calculation
  float    WetValue = 1.07f; // value found by putting sensor in water
  float    DryValue = 2.732f; // value of probe when held in air
  float    Range = DryValue - WetValue;
  float    RemainingMoisture = 100.0f;
  SimpleKalmanFilter KF_ADC_b( 1.0f, 1.0f, .01f );
  for (;;)
    xEventGroupWaitBits (eg, evtADCreading, pdTRUE, pdTRUE, portMAX_DELAY ); //
    adcValue_b = float( adc1_get_raw(ADC1_CHANNEL_3) ); //take a raw ADC reading
    adcValue_b = ( adcValue_b * uPvolts ) / ADbits; //calculate voltage
    KF_ADC_b.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
    adcValue_b = KF_ADC_b.updateEstimate( adcValue_b ); // apply simple Kalman filter
    TimePastKalman = esp_timer_get_time(); // time of update complete
    RemainingMoisture = 100.0f * (1 - ((adcValue_b - WetValue) / (DryValue - WetValue))); //remaining moisture =  1-(xTarget - xMin) / (xMax - xMin) as a percentage of the sensor wet dry volatges
    xQueueOverwrite( xQ_RM, (void *) &RemainingMoisture );
    //log_i( "adcValue_b = %f remaining moisture %f%", adcValue_b, RemainingMoisture );
  vTaskDelete( NULL );
void fPublish( void * parameter )
  for (;;)
    if ( xQueueReceive(xQ_RemainingMoistureMQTT, &RemainingMoisture, portMAX_DELAY) == pdTRUE )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.publish( topicRemainingMoisture_0, String(RemainingMoisture).c_str() );
      xSemaphoreGive( sema_MQTT_KeepAlive );
  } // for (;;)
} //void fPublish( void * parameter )
void WaterPump0_off()
  gpio_set_level( GPIO_NUM_4, LOW); //denergize relay module
  vTaskDelay( 1 );
  gpio_set_level( GPIO_NUM_5, LOW); //denergize/close valve
void WaterPump0_on()
  gpio_set_level( GPIO_NUM_5, HIGH); //energize/open valve
  vTaskDelay( 1 );
  gpio_set_level( GPIO_NUM_4, HIGH); //energize relay module
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 85000; // get another reading when = UpdateTimeTrigger
  int maxNonMQTTresponse = 12;
  TickType_t xLastWakeTime = xTaskGetTickCount();
  const TickType_t xFrequency = 5000; //delay for mS
  for (;;)
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
    xSemaphoreTake( sema_mqttOK, portMAX_DELAY ); // update mqttOK
    mqttOK++;
    if ( mqttOK >= maxNonMQTTresponse )
      ESP.restart();
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
} //void fmqttWatchDog( void * paramater )
void fDoMoistureDetector( void * parameter )
  //wait for a mqtt connection
  while ( !MQTTclient.connected() )
    vTaskDelay( 250 );
  int      TimeToPublish = 5000000; //5000000uS
  int      TimeForADreading = 100 * 1000; // 100mS
  uint64_t TimePastPublish = esp_timer_get_time(); // used by publish
  uint64_t TimeADreading   = esp_timer_get_time();
  const TickType_t xFrequency = 10; //delay for 10mS
  float    RemainingMoisture = 100.0f; //prevents pump turn on during start up
  bool     pumpOn = false;
  uint64_t PumpOnTime = esp_timer_get_time();
  int      PumpRunTime = 11000000;
  uint64_t PumpOffWait = esp_timer_get_time();
  uint64_t PumpOffWaitFor = 60000000; //one minute
  float    lowMoisture = 23.0f;
  float    highMoisture = 40.0f;
  for (;;)
    //read AD values every 100mS.
    if ( (esp_timer_get_time() - TimeADreading) >= TimeForADreading )
      xEventGroupSetBits( eg, evtADCreading );
    xQueueReceive(xQ_RM, &RemainingMoisture, 0 ); //receive queue stuff no waiting
    //read gpio 0 is water level good. Yes: OK to run pump : no pump off.   remaining moisture good, denergize water pump otherwise energize water pump.
    if ( RemainingMoisture >= highMoisture )
      WaterPump0_off();
    if ( !pumpOn )
      log_i( "not pump on ");
      if ( gpio_get_level( GPIO_NUM_0 ) )
        if ( RemainingMoisture <= lowMoisture )
          //has one minute passed since last pump energize, if so then allow motor to run
          if ( (esp_timer_get_time() - PumpOffWait) >= PumpOffWaitFor )
            WaterPump0_on();
            log_i( "pump on " );
            pumpOn = !pumpOn;
        //xSemaphoreGive( sema_RemainingMoisture );
        log_i( "water level bad " );
        WaterPump0_off();
         pump goes on runs for X seconds then turn off, then wait PumpOffWaitTime before being allowed to energize again
      if ( (esp_timer_get_time() - PumpOnTime) >= PumpRunTime )
        log_i( "pump off " );
        WaterPump0_off(); // after 5 seconds turn pump off
        pumpOn = !pumpOn;
    // publish to MQTT every 5000000uS
    if ( (esp_timer_get_time() - TimePastPublish) >= TimeToPublish )
      xQueueOverwrite( xQ_RemainingMoistureMQTT, (void *) &RemainingMoisture );// data for mqtt publish
      TimePastPublish = esp_timer_get_time(); // get next publish time
}// end fDoMoistureDetector()
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  const TickType_t xFrequency = 250; // 250mS
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
  vTaskDelete ( NULL );
void connectToMQTT()
  // create client ID from mac address
  byte mac[5];
  int count = 0;
  WiFi.macAddress(mac); // get mac address
  String clientID = String(mac[0]) + String(mac[4]);
  log_i( "connect to mqtt as client %s", clientID );
    MQTTclient.disconnect();
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
    vTaskDelay( 250 );
    count++;
    if ( count == 5 )
      ESP.restart();
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( topicOK );
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
} // void connectToWiFi()
void fparseMQTT( void *pvParameters )
  struct stu_message px_message;
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      if ( px_message.topic == topicOK )
        mqttOK = 0; // clear mqtt ok count
      if ( !TimeSet )
        String temp = "";
        temp = px_message.payload[0];
        temp += px_message.payload[1];
        temp += px_message.payload[2];
        temp += px_message.payload[3];
        int year =  temp.toInt();
        temp = "";
        temp = px_message.payload[5];
        temp += px_message.payload[6];
        int month =  temp.toInt();
        temp = "";
        temp = px_message.payload[8];
        temp += px_message.payload[9];
        int day =  temp.toInt();
        temp = "";
        temp = px_message.payload[11];
        temp += px_message.payload[12];
        int hour =  temp.toInt();
        temp = "";
        temp = px_message.payload[14];
        temp += px_message.payload[15];
        int min =  temp.toInt();
        rtc.setTime( 0, min, hour, day, month, year );
        log_i( "%s  ", rtc.getTime() );
        TimeSet = true;
      // manual pump control
      if ( str_eTopic == topicPumpState )
        if ( String(strPayload) == "off" )
          WaterPump0_off();
        if ( String(strPayload) == "on" )
          WaterPump0_on();
          manualPumpOn = true;
  } //for(;;)
} // void fparseMQTT( void *pvParameters )
void loop() {}
sorry man if i gone too far,I am just 12 year old kid....
okay no matters if anyone would not make code for me :wink:
thanks
and sorry for the inconvenience
Hello
I´m deep frozen.
What is you budget to do this job?
it doesn't matter but you in insist i will tell
its $100 bucks
No problem man. I had hoped the code I posted would help jump start your project. Anyways good luck.
thnx
Have you heard the one about horses and carts, one being put before the other ?
It’s admirable that you’re starting out so young, but the experience of trying to solve this yourself will help you in life…. along with the horse/cart paradigm.
Don’t worry, we’re always here to help when you get stuck, but you may have noticed this is the Arduino Forum, not the Arduino Academy.
OK, but know for sure: you don't get to say "just" or "only" before your age for but a year or two more.
When you are fourteen, you gonna be fourteen, neither just fourteen, nor only fourteen.
:wink:
a7
You have to break the project down in stages, first checking that you can interface to each device.
Can the pump be driven directly from an Arduino pin ?
Ask the moderator to move your post to the Jobs and Paid Consultancy forum section.
I'm going to argree with the OP
Chill out.
He is not looking to hire someone
He is lookikg for beginners help and guidance.
Get a water sensor and find a tutorial and vides.
Have some fun and welcone to the fire pit of hot coals.
This is what the OP asked. My recommendation to post on the Jobs and Paid Consultancy section stands.
I suggest you break the code down to each component. I'm sure each part (16*2 LCD / i2c, Flow rate sensor, ir sensor, pump, keypad) has example code you can find with a search and copy to your IDE.
Once you have each component running properly combining and defining exactly what the code needs to do is the next step.
When I was a young man, my brother wanted me to help repair his car. By help he meant do as he was not mechanically inclined. I would always help him but I'm make sure he got his hands at least as dirty as mine.
I suspect the folks here feel the same way.
John
To me, this has most of the characteristics of a school project, and should not end up as contract job, namely:
  1. A relatively clearly defined and testable objective.
  2. Already a logical collection of components to fulfil that objective.
  3. A "maker" with no real idea of how to proceed.
An alternative explanation of why the OP is engaged in this activity would have to be quite good to convince me otherwise.
No arguments here.
But a noob is a noob is a noob.
What we usually say is "what have you tried?"
And "get some parts and tell us what you found"
But i could be wrong.
He may be paying someone and be putting himself on the path to management.
