This board has an ESP8266MOD WiFi module on it and a CP2102 USB to Serial interface on it.
The problem with both boards is when I plug them into my computer (running Linux), they do not show up as a USB device.
I have other CP2102 breakout boards and these "just work" on my computer. They are seen as "/dev/ttyUSB0".
I tried using short, sturdy USB cables (making sure the board had a good connection to the USB). I also tried a 1000 uF capacitor across the 3.3 volt board supply and the 5.0 volt incoming USB power.
Upon powerup, a blue LED on the WiFi module flashes a few times, then stays dark. Pressing "reset" causes the blue LED to blink the same pattern, then stay dark.
Nothing seems to work.
I then took one of my CP2102 breakout boards and connected it to the TX, RX, 3V3 and GND pins of the WiFi board.
The board SOMETIMES would start up, displaying a few characters of garbage, then a readable string that something like "AI Thinker", but upon trying to type commands, nothing happened (no characters echoed, no response from the board).
I have 2 of these boards, and they both act the same way, so I'm quite sure the boards themselves are not bad (at least it seems unlikely that 2 would have the same exact problem).
Did you try plugging in the usb while holding down the 'flash' switch? That may be how you get it in bootloader mode? I don't kniw why the usb interface isn't showing up.
That shouldn't fix the problem. My guess is that you received a faulty module. Tro hooking up an FTDI adapter and see if it works
Common enough Chinese board ... I have a lot of 10 marked "Lolin" and I use Linux Mint 18 with no issues. All the boards enumerate properly.
One of the biggest gripes I have heard about the NodeMCU boards with the micro-USB is that sometimes the reflow soldering process does not properly solder the USB connecting end to the breakout board which of course keeps USB from working. I have hot-air reflow in the lab and while the Lolin boards have not given me any problems, I have had a few STM32 Chinese clones that had to be reworked a bit.
I suggest taking a micro-USB that does not have the PC end attached ... that is, broken out for access to the wire. You already know ground and +5 must be working (the blue light flashes), so D+ and D- are suspect. Use a DVM on the Ohm scale to test.
I recently got the same NodeMCU. It had the same problems. I have connected to the UART with an external adapter - it worked. I looked at the CP2102 through a magnifying glass - one side was not soldered :o ! Chinese >:( ! I soldered the CP2102 reliable - now it works correctly !
P.S. Connection speed over UART for this chinese module usually is 78800
