how to make and use a class
Is it possible to make a class in a .pde file? Something like this processing example? http://webzone.k3.mah.se/projects/arduino-workshop/projects/arduino_meets_processing/instructions/accelero.html When I make a new tab in which I make a class arduino say's: "error: 'OneWireLib' does not name a type" Here is "OneWireLib" the name of the .pde file and the class. For now the class is virtually empty:
class OneWireLib
OneWireLib()
  int y =1;
void ConvertTemp()
  int x =1;
In my main program I call the class like this:
OneWireLib owl;
I see a few things that might help:
  • Make sure you put a semicolon ‘;’ after the final ‘}’ in the class declaration.
  • you will need to make some things “public” if you access them from outside the class. By default, members of a class are “private”.
  • You should declare variables as members of the class if they are part of the object.
Here is an example of what I mean:
class OneWireLib
public:
    OneWireLib()
        int y =1;       // this 'y' will go away once the constructor returns (it is a local variable)
        somevar = 99;     // initialize class member variables here in the constructor
    void ConvertTemp()
         int x =1;
    int GetSomeVar()    // example of method for using private data
        return somevar;
private:
     int somevar;      // put variables that are part of the object here
};        // <===  note semicolon here... terminates the class declaration
OneWireLib  onewire;     // declare an instance of the OneWireLib class
    int x = onewire.GetSomeVar();     // example of calling a class method
I tried you're example using a second tab and it doesn't work. This is the error: error: 'OneWireLib' does not name a type In function 'void test()':
But, if I try it in one file it does work. What's the difference? I tried to #include the file but it is not found.
Please post your code and I will see if I can help.
The mainfile testclass.pde:
// #include "onewire.pde"
and the class file onewire.pde:
class OneWireLib
public:
    OneWireLib()
    void ConvertTemp()
         int x =1;
        return somevar;
private:
the onewire.pde file is in the same directory as the testclass.pde file.
And again, all this code in one file does work.
OK, now I understand. I too have had problems trying to #include a header file in the same directory as my sketch. Looks like Arduino does NOT put the sketch directory inside the C++ include path. But it looks like maybe you are trying to make a reusable library. Try taking a look at this:
http://www.arduino.cc/en/Main/Libraries
I didn't start the thread for a reusable library. It was more to get my code more readable. So I figured that a class in another tab would be helpful. After reading this http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1167857708 thread I figured it would be easy to do. :)
If the #include statement uses "double quotes", the compiler will check the directory that the including file is in (i.e. the sketch directory). You just need to add to your sketch a .h file with the appropriate contents, and place the #include statement at the top of the main sketch file, and you should be fine.
But is this .h necessary? If you start a new tab the file will be saved as a .pde file. So, I expected that a #include "onewire.pde" would work, but it doesn't.
Okay, I tried it. If I rename the onewire.pde to onewire.h and I use "#include "onewire.h" it works. And it gets better, if I save the file als foo.h it won't get the pde extension. But this might be something platform specific? (I am on OSX) So, only one question left: why does .h work and .pde not?
