How to make Arduino runs continuous routines even inside a "switch case loop".
AWOL:
As suggested by PeterH, I've changed some of the code
No, you didn't change it as he suggested. Read the post again, particularly around the reading of the serial port.
If the character read is global and therefore persistent, then once read, it will trigger the appropriate action every time through "loop ()" until a new character is read.
Holy crap!! I feel so stupid for the mistake I've done.. I'm sorry! now it works!!!!
Here is the sketch!
//includes necessary libraries
#include <......>
//Some setup & variables/constants declaration & other stuff
char ch=0; //global variable for Serial.read()
  //arduino/sensor setup and other stuff
void loop(){
  if(Serial.available()){
    ch=Serial.read();}
    switch(ch)
      case '1':
      SHT1();
      break;
      case '2':
      SHT2();
      break;
      case '3':
      Pres();
      break;
      case '4':
      LIGHT1();
      break;
      case '5':
      LIGHT2();
      break;
void SHT1(){
  // do measurement and return ONE DATA
void SHT2(){
void Pres(){
    // do measurementS and RETURN DATA AS LONG AS USER PRESS ONE KEY TO STOP MEASUREMENT
void LIGHT1() {
void LIGHT2() {
Is it a correct way adding "ch=0;" inside a case to get only a value from the selected case?
something like this:
case '1':
      SHT1();
      ch=0;
      break;
Thank You all very very much!!!
