How to make automatic communication between Arduino Mega & Esp01 to the Google Sheet
I need some help. I have write my coding and all has function well on the hardware. But i have some problem for the google sheet communication. why my hardware cannot sent the data to the google sheet automatic. it need to copy the https link that produce by Arduino and paste to the google. My project is about price indicator RFID Trolley. It means If the UID card been scan and it will read at the LCD and these has 6 button which is for accept, unaccepted, ++,--, remove item and for done buying. The problem is when I push the button these only give a calculated to the Hardware only. It not sent to the google sheet. I will show my coding.
#At Arduino#
RFID PN532 Uno
SCK         D13
MSO         D12
MOSI        D11
SS (SDA)    D10
VCC         3.3V
GND         GND
IRQ         Non
RSTO        D9
RFID PN532 Mega
SCK       D52
MSO       D50
MOSI      D51
SS (SDA)  D53
VCC       3.3V
GND       GND
IRQ       Non
RSTO      D49
______________
Push Button
Pin   2 Select Item
Pin   3 TotDisplay Item
Pin   4 Quantity ++
Pin   5 Quantity -
Pin   6 Remove Item
Pin   7 Done Buying
Signal Component
Pin  22 Led Red
Pin  24 Led Yellow
Pin  26 Led Green
Pin  28 Buzzer
LCD
SDA  20
SCL 21
5V
GND
#include <SPI.h>
#include <Adafruit_PN532.h>
/*########################### Setup Wifi Module  ############################*/
#include "WiFiEsp.h"
// Emulate Serial1 on pins 7/6 if not present
#ifndef HAVE_HWSERIAL1
#include "SoftwareSerial.h"
SoftwareSerial Serial1(6, 7); // RX, TX
#endif
char ssid[] = "??";                   // your network SSID (name)
char pass[] = "password11223344";     // your network password
int status = WL_IDLE_STATUS;          // the Wifi radio's status
// Initialize the Ethernet client object
WiFiEspClient client;
/*########################### Google Script Variable  ############################*/
String urlGscript = "script.google.com/macros/s/AKfycbzXVE8HiqMC6VVrWMcjVUV0hIcmC5969DOUfWZINiIVQjiRTIrblsdeOswT3VxcLz_pyg/exec?"; // base url for google apps script
String urlFinal = "";        // will change based on cart condition
// Time
#define TIMEOUT_MS 5000
// RFID
#define PN532_SCK 13
#define PN532_MISO 12
#define PN532_MOSI 11
#define PN532_SS 10
Adafruit_PN532 nfc(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS);
// LCD
LiquidCrystal_I2C lcd(0x27, 16, 2); // I2C address 0x27, 16 column and 2 rows
bool userChoice = false; // User has not made a choice yet
float Input = 0;         // input for Item price
float TotValue = 0;      // Total Price iteam
float Value = 0;         // valur for each item
String itemName = "";
String itemUID = "";
int Item = 0; // count Product
int minValue;
int i;
int p1 = 0, p2 = 0, p3 = 0, p4 = 0, p5 = 0;
/*########################### Void Setup Starting  ############################*/
  // INPUT PIN
  pinMode(2, INPUT_PULLUP); // wants
  pinMode(3, INPUT_PULLUP); // didn't wants
  pinMode(4, INPUT_PULLUP); // ++ Item
  pinMode(5, INPUT_PULLUP); //   - Item
  pinMode(6, INPUT_PULLUP); // Remove Item// Done Buying
  pinMode(7, INPUT_PULLUP); // Done Buying
  // OUTPUT PIN
  pinMode(22, OUTPUT); // RED LED
  pinMode(24, OUTPUT); // YELLOW LED
  pinMode(26, OUTPUT); // GREEN LED
  pinMode(28, OUTPUT); // BUZZER
  Serial.begin(115200); // Initiate a serial communication
  // initiate communication with esp
  Serial1.begin(115200);
  WiFi.init(&Serial1);
  // check for the presence of the shield
  if (WiFi.status() == WL_NO_SHIELD)
    Serial.println("WiFi shield not present");
    // don't continue
    while (true)
  // attempt to connect to WiFi network
  while (status != WL_CONNECTED)
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network
    status = WiFi.begin(ssid, pass);
  Serial.println("You're connected to the network");
  printWifiStatus();
  // Start Cording
  lcd.begin(); // initialize the lcd
  lcd.backlight();
  nfc.begin();          // Initiate  PN532
  Starting();
  // lcd.print();
  // Serial.println();
    for (int position = 0; position < 23; position++)
      lcd.setCursor(0, 0);
      lcd.scrollDisplayLeft();
      lcd.print("  Welcome to The Market... ");
      delay(300);
  lcd.clear();
  lcd.print("Please Scan Items");
  delay(200);
/*############################ Void Loop starting ##############################*/
  uint8_t success;
  uint8_t uid[] = {0, 0, 0, 0, 0, 0, 0}; // Buffer to store the returned UID
  uint8_t uidLength;                     // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  if (digitalRead(7) == LOW)
    lcd.clear();
    lcd.print(" Done Buying ?");
    lcd.setCursor(0, 1);
    lcd.print(" Hold / || Hold X");
  if (digitalRead(2) == LOW)
    lcd.clear();
    lcd.setCursor(3, 0);
    lcd.print("Thank you");
    delay(2000);
    for (i = 0; i < 25; i++)
      lcd.print(" Please show the Barcode to the counter");
    TotDisplay();
  else if (digitalRead(3) == LOW)
    lcd.clear();
    lcd.print("Scan Items");
    delay(2000);
    lcd.clear();
    TotDisplay();
    return loop();
    success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength, TIMEOUT_MS);
    if (!success)
      digitalWrite(22, 1); // RED
      digitalWrite(26, 1); // YELLOW
      digitalWrite(22, 0); // RED
      digitalWrite(26, 0); // Buzzer
      return;
    // Show UID on serial monitor
    Serial.print("UID tag :"); // If want to show UID tag
    String content = "";
    for (byte i = 0; i < uidLength; i++)
      Serial.print(uid[i] < 0x10 ? " 0" : " ");
      Serial.print(uid[i], HEX);
      content.concat(String(uid[i] < 0x10 ? " 0" : " "));
      content.concat(String(uid[i], HEX));
    lcd.clear();
    lcd.print("Item : ");
    Process();
    content.toUpperCase();
    Input = Serial.parseFloat();
    /*############################ RFID TAG PARTS ####################################*/
    if ((content.substring(1) == "53 FD 6A AB 71 00 01") || (content.substring(1) == "53 C8 C4 AC 71 00 01")) // change here the UID of the card/cards that you want to give access
      lcd.setCursor(6, 0);
      lcd.print(" Maggie");
      lcd.print("Price: RM 3.50");
      Input = 3.50;
      Item = 1;
      itemName = "Maggie";
      itemUID = "53 FD 6A AB 71 00 01";
      p1;
    else if ((content.substring(1) == "53 F4 6E AB 71 00 01") || (content.substring(1) == "53 B9 56 AB 71 00 01")) // sec item
      lcd.print(" Bekas");
      lcd.print("Price: RM 5.00");
      Input = 5;
      Item = 1;
      itemName = "Bekas";
      itemUID = "53 F4 6E AB 71 00 01";
      p2;
    else if (content.substring(1) == "53 FC 72 AB 71 00 01") // third item
      lcd.print(" Lifebuoy ");
      lcd.print("Price: RM 7.00");
      Input = 7;
      Item = 1;
      itemName = "Lifebuoy";
      itemUID = "53 FC 72 AB 71 00 01";
      p3;
    else if ((content.substring(1) == "53 2A 64 AB 71 00 01") || (content.substring(1) == "53 1E 5A AB 71 00 01")) // fourth item
      for (i = 0; i < 20; i++)
        lcd.print(" Mushroom Carbonara");
        delay(300);
      lcd.clear();
      lcd.print("Price: RM 7.50");
      Input = 7.50;
      Item = 1;
      itemName = "Mushroom Carbonara";
      itemUID = "53 2A 64 AB 71 00 01";
      p4;
    else if (content.substring(1) == "53 0D 67 AB 71 00 01") // Fifth item
      lcd.print(" Holick");
      lcd.print("Price: RM 10.50");
      Input = 10.50;
      Item = 1;
      itemName = "Holick";
      itemUID = "53 0D 67 AB 71 00 01";
      p5;
      /*for(i = 0; i < 20; i++)
      lcd.setCursor(6,0);
      delay(300);
      lcd.clear();
      lcd.setCursor(6,0);
      lcd.setCursor(0,1);
      Input = 10.50;
      Item = 1;
      p5;
      delay(500);*/
      Error();
      lcd.clear();
      lcd.print(" Error!");
      lcd.setCursor(1, 1);
      lcd.print(" Rescan Item ");
      delay(2000);
      TotDisplay();
      return loop();
    /*##################################### Quantity Parts #####################################*/
    while (i = 1)
      if (digitalRead(4) == LOW)
        IncreaseItem();
      if ((digitalRead(5) == LOW) && (i >= 0))
        DecreaseItem();
      /*##################################### Customer Picking Parts #####################################*/
      // Customer Wanna buy or not
      if (digitalRead(2) == LOW) // Want the item
        lcd.clear();
        userChoice = true;
        Granted();
        for (i = 0; i < 8; i++)
          lcd.print(" InCart "); // wants the item
        { // first item
          p1 = p1 + Item;
          urlFinal = urlGscript + "uid=" + itemUID + "&item_name=" + itemName + "&item_price=" + String(Input) + "&item_quantity=" + String(p1) + "&action_type=add";
        { // sec item
          p2 = p2 + Item;
          urlFinal = urlGscript + "uid=" + itemUID + "&item_name=" + itemName + "&item_price=" + String(Input) + "&item_quantity=" + String(p2) + "&action_type=add";
        { // third item
          p3 = p3 + Item;
          urlFinal = urlGscript + "uid=" + itemUID + "&item_name=" + itemName + "&item_price=" + String(Input) + "&item_quantity=" + String(p3) + "&action_type=add";
        { // four item
          p4 = p4 + Item;
          urlFinal = urlGscript + "uid=" + itemUID + "&item_name=" + itemName + "&item_price=" + String(Input) + "&item_quantity=" + String(p4) + "&action_type=add";
        { // fith item
          p5 = p5 + Item;
          urlFinal = urlGscript + "uid=" + itemUID + "&item_name=" + itemName + "&item_price=" + String(Input) + "&item_quantity=" + String(p5) + "&action_type=add";
        TotAdds();
        sendToSheet(urlFinal);
        return loop();
      else if (digitalRead(3) == LOW) // Didn't want the item
        lcd.clear();
        userChoice = true;
        Granted();
        for (i = 0; i < 9; i++)
          lcd.print(" Unaccept "); // wants the item
          delay(400);
        TotDisplay();
        return loop();
      /*##########################  Remove Item  ###################################*/
      if (digitalRead(6) == 0)
        digitalWrite(28, 1); // Buzzer
        delay(200);
        digitalWrite(24, 0); // Yellow
        delay(50);
        digitalWrite(28, 0); // Buzzer
        delay(100);
        digitalWrite(26, 1); // RED
        digitalWrite(26, 0); // RED
        delay(50);
        if ((content.substring(1) == "53 FD 6A AB 71 00 01" ) || (content.substring(1) =="53 C8 C4 AC 71 00 01" )) // First Item
          if (p1 > 0)
              lcd.print(" Remove Maggie");
              lcd.print("Price:-RM 3.50");
              delay(200);
            TotValue = TotValue - 3.50;
            p1--;
            ZeroChecker();
            return loop();
            Error();
            lcd.clear();
            NoIncart();
            TotDisplay();
            return loop();
        else if ((content.substring(1) == "53 F4 6E AB 71 00 01" ) || (content.substring(1) == "53 B9 56 AB 71 00 01")) // sec item
          if (p2 > 0)
              lcd.print(" Remove Bekas");
              lcd.print("Price:-RM 5.00");
              delay(200);
            TotValue = TotValue - 5;
            p2--;
            ZeroChecker();
            return loop();
            Error();
            lcd.clear();
            NoIncart();
            TotDisplay();
            return loop();
          if (p3 > 0)
              lcd.print(" Remove Lifebuoy");
              lcd.print("Price:-RM 7.00");
              delay(200);
            TotValue = TotValue - 7;
            p3--;
            ZeroChecker();
            return loop();
            Error();
            lcd.clear();
            NoIncart();
            TotDisplay();
            return loop();
          if (p4 > 0)
            for (i = 0; i < 26; i++)
              lcd.print(" Remove Mushroom Carbonara");
              lcd.print("Price:-RM 7.50");
              delay(200);
            TotValue = TotValue - 7.50;
            p4--;
            ZeroChecker();
            return loop();
            Error();
            lcd.clear();
            NoIncart();
            TotDisplay();
            return loop();
          if (p5 > 0)
            for (i = 0; i < 14; i++)
              lcd.print(" Remove Holick");
              lcd.print("Price: -RM 10.50");
              delay(200);
            TotValue = TotValue - 10.50;
            p5--;
            ZeroChecker();
            return loop();
            Error();
            NoIncart();
            TotDisplay();
            return loop();
  // if the server's disconnected, stop the client
  if (!client.connected())
    Serial.println("Disconnecting from server...");
    client.stop();
    while (true);
/* ###########Void Code##################*/
void printWifiStatus(){
  // print the SSID of the network you're attached to
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength
  long rssi = WiFi.RSSI();
  Serial.print("Signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
void sendToSheet(String url){
  // send GET Request
  Serial.println("Sending data to google sheet");
  Serial.println(url);
  client.print(String("GET ") + url + " HTTPS/1.1\r\n" +
               "Host: " + "script.google.com" + "\r\n" +
               "Connection: close\r\n\r\n");
  /*unsigned long timeout = millis();
  while (client.available() == 0)
    if (millis() - timeout > 10000)
      Serial.println(">>> Client Timeout !");
      client.stop();
      return;
  // Read all the lines of the reply from server and print them to Serial
  while (client.available())
    String line = client.readStringUntil('\r');
    Serial.print(line);
  // Close connection
  Serial.println("closing connection");
  client.stop();
void Starting(){
  digitalWrite(24, 1); // YELLOW
  digitalWrite(26, 1); // GREEN
  digitalWrite(22, LOW); // RED
  digitalWrite(24, LOW); // YELLOW
  digitalWrite(26, LOW); // GREEN
void NoIncart(){
  lcd.clear();
  lcd.print("No Incart!");
void Process(){         // for starting process UID
  digitalWrite(28, 1); // buzzer
  delay(100);
  digitalWrite(24, 1); // Yellow
  delay(50);
void Granted(){         // LED access
  delay(100);
  delay(50);
  delay(100);
  digitalWrite(26, 1); // Green
  digitalWrite(26, 0); // Green
  delay(50);
void Error(){           // LED Error
  delay(200);
  delay(50);
  delay(100);
  delay(200);
  delay(100);
  digitalWrite(22, 1); // Yellow
  digitalWrite(22, 0); // Yellow
  delay(50);
void ZeroChecker(){     // Value Not zero
  if (TotValue < minValue)
    TotValue = 0; // set value to minimum allowed value
  lcd.clear();
  lcd.print(" Total Price: ");
  lcd.print(" Rm ");
  lcd.print(TotValue);
void TotAdds(){         // display with add calculation
  lcd.clear();
  lcd.print("Total Price: ");
  TotValue = TotValue + (Input * Item);
  lcd.print("RM ");
  lcd.setCursor(3, 1);
  lcd.print(TotValue, 2);
void TotDisplay(){      // Value display without calculation
  lcd.clear();
  TotValue = TotValue;
  lcd.print("RM ");
void IncreaseItem(){    // Item Check more than one
  lcd.clear();
  lcd.print("Quantity: ");
  Item = Item + 1;
  i++;
  lcd.print(Item);
  lcd.print("Price:RM ");
  lcd.setCursor(9, 1);
  Value = Input * Item;
  lcd.print(Value);
void DecreaseItem(){    // Item Check less Item IncreaseItem
  lcd.clear();
  Item = Item - 1;
  i--;
  if (Item < minValue)
    Item = 0; // set value to minimum allowed value
  lcd.print(Item);
  if (Value < minValue)
  lcd.print(Value);
And this is at the Appscript for google sheet
function doGet(e) {
  var ss = SpreadsheetApp.openByUrl("https://docs.google.com/spreadsheets/d/1jdP620MyhF-75FRpavHCx8FnN2aLqV7d8_hmsufm_kM/edit#gid=0");
  var sheet = ss.getSheetByName("Cart");
  addData(e, sheet);
function addData(e, sheet) {
  var uid = e.parameter.uid;
  var item_name = e.parameter.item_name;
  var item_price = e.parameter.item_price;
  var item_quantity = e.parameter.item_quantity;
  var quantity = item_quantity * item_price;
  var timestamp = new Date();
  var actionType = e.parameter.action_type ?? "add";
  var uidColumn = sheet.getRange("A1:A100" + sheet.getLastRow());
  var tf = uidColumn.createTextFinder(uid).findAll();
  try {
    if (actionType == "add" && item_quantity > 0) {
      if (tf.length > 0) {
        var row = tf[0].getRow();
        console.log("Updating sheet");
        sheet.getRange(row, 4).setValue(item_quantity);
        sheet.getRange(row, 5).setValue(quantity);
        sheet.getRange(row, 6).setValue(timestamp);
        return;
        console.log("Writing to sheet");
        console.log(uid, item_name, item_price, item_quantity, timestamp);
        sheet.appendRow([
          uid,
          item_name,
          item_price,
          item_quantity,
          quantity,
          timestamp,
    } else if(actionType == "add" && item_quantity == 0) {
        console.log("Deleting row %s", row);
        sheet.deleteRow(row);
        // shift rows up
        sheet.getRange(row, 1, sheet.getLastRow() - row + 1, 6).moveTo(
          sheet.getRange(row, 1)
        console.log("No row to delete");
        // shift rows up
  } catch (e) {
    console.log("Failed with error %s", e.message);
