How to make cam OV7670 work with Arduino?
Hello,
what is the most simply way to make OV7670 cam module work with Arduino?
Isn't more feasible to connect some cam module to a RaspberryPi right away?
Thanks!
178,000 results on Google.
It's nice from you :slight_smile: I searched the Google at first but not found clear solution and so I decided to ask someone more experienced for the help.
It seems a DDS processor with TTL output is needed and ArduCAM-like module are often used. But costmore than Raspberry Pi board which has FIFO interface.
I just would like to learn basic work with image processing.
What is by your opinion the best way to make the cam works?
