How to make commands?
How can I create commands and put them in my code?
I want to use the commands in the serial monitor.
What do you mean?
Search for : arduino command interpreter I often write my own, in most cases I use a single character: 'H' and '?' for help info, 'L' for led, and so on.
kashashin: How can I create commands and put them in my code?
In this message I have posted an example sketch:
http://forum.arduino.cc/index.php?topic=301466.msg2101661#msg2101661
The sketch understands different devices like "led", "motor", "pump", "relay". And for each device three commands are supported: "on", "off", "click"
So from the serial monitor you can send commands like: motor on pump off led click 500
where the "click" action perhaps needs some explanation: The "click" command is executing a non-blocking action sequence of - "switch on" - "stay on for the number of milliseconds given as a parameter" - "switch off"
I use this when doing simple EEPROM updates to my calibrations.
void eeprom1()
  while (Serial.available() > 0)
    char inByte = Serial.read();
    while(inByte == 'r')
      eepromr();        //this function reads the address and displays the value at said address
    while(inByte == 'w')
      eepromwr();    //this function writes to the address and displays the written value
It works quit well.
Bill
A very simple example of sending a command from the serial monitor to the arduino.
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
int ledPin = 13;
String readString;
  pinMode(ledPin, OUTPUT);
  Serial.println("serial on/off test 0021"); // so I can keep track
  while (Serial.available()) {
    delay(3);
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    if (readString == "on")
      digitalWrite(ledPin, HIGH);
      Serial.println("LED ON");
    if (readString == "off")
      digitalWrite(ledPin, LOW);
      Serial.println("LED OFF");
    readString="";
