How to make DC motor go forward, stop and reverse?
I'm trying to control a DC motor via a push button which will make the DC motor go in the forward, reverse or stop depending on the number of pushes. Here's a picture of the schematic of the setup. My question is what is the code or function that I need to put in in order to make it go forward, reverse, and stop? And no involvement of a h bridge.
Here's a sample of what I "think" would make the DC motor stop, go forward, and reverse based on reading through numerous websites. This is just part of my whole code.
if (MotorMode == 0) { // initial mode
    digitalWrite(relayPin, LOW); // Motor in initial state
  if (MotorMode == 1) { // Motor in the forward direction
    digitalWrite(relayPin, HIGH);
  if (MotorMode == 2) { // Motor stops
  if (MotorMode == 3)  { // Motor goes in the reverse direction
In your drawing pin 1 controls motor on or off. Pin 2 controls forware or reverse. So:
    digitalWrite(1, LOW); // Motor in initial state = off
    digitalWrite(2, HIGH);  // turn direction relay on for forward direction
    digitalWrite(1, HIGH);  // turn motor voltage on
    digitalWrite(1, LOW);  //turn motor voltage off
    digitalWrite(2, LOW); //turn direction relay off for reverse direction
Be sure you have a wire from the 9 volt supply negative terminal to the arduino ground pin, it's required.
Lefty
To stop the motor with locked rotor is necessary to short the terminals and the cricuito can not do it.
Edson
retrolefty:
Lefty
Thank you so much! I was so confused on why there was a pin 2 schematic on the bottom right not attached to the motor transistor / relay schematic in the top left.
retrolefty:
Lefty
I would need to define pin 2 at the beginning of my code though right or else the code will not recognize what pin 2 is?
Like this:
int buttonPin = 6;              // pushbutton switch is connected to pin 6
int MotorMode = 0;              // Motor position
int MotorPin = 1;              // motor is connected to pin 1
int RelayPin = 2;              // Relay connected to pin 2
  pinMode(buttonPin, INPUT);    // Declare pushbutton as input
  pinMode(relayPin, OUTPUT);    // Declare relay as output
  pinMode(MotorPin, OUTPUT):    // Declare motor as output
gnozahs:
retrolefty:
Lefty
Like this:
int ForwardOrReversePin = 2;              // connected to pin 2
If you wish. However digitalWrite commands will accept using the actual digital pin number in the command. It is however considered good paractice to utilize names for your constants rather then just using 'magic numbers' that later may not be as easily understood when reading the code.
Good luck;
Lefty
retrolefty:
gnozahs:
retrolefty:
Lefty
Like this:
Good luck;
Lefty
I am a noob and super weak at programming so I like to name my variables or whatever they're called so I don't get confused XD
As I said that is a good practice to follow beginner or not. Back to constants Vs variables, one uses a variable where the value of the variable can or does change as the program runs. Constants are used where the value needs to stay the same at all times (read only value) when the program runs. Either will work for the digitalWrite command but it's a good habit to understand and learn the difference and utilize them properly.
http://arduino.cc/en/Reference/Const
http://arduino.cc/en/Reference/VariableDeclaration
Lefty
Gnozahs, do you happen to have a parts list for the schematic you posted. ps sorry to resurrect an old thread but this is exactly what I need to do.
This thread shows how not to control a motor - you should use the much simpler H- bridge circuit and you should never ever use a relay for any thing.
Mark
It does?
You shouldn't?
Oops.
how would be able to control this circuit/design using and LDR to automatically turn on in the morning and off
