How to make Device work 24/7 without human intervention? ?
I Made a PCB which has
  1. Atmega328p-pu
  2. SIM800L
  3. Lm2596 based power supply gives 4v 2A to GSM
  4. BMP180
    5)LCD16*2
    This board is connected to BLYNK server, It worked properly for two days,every second it pinged proper sensor data to BLYNK server, but today It was disconnected from network, Then I had to manually restart the Device, it again started to work normally, but I don't want to Do this manually , I want to use this in Agricultural field, how to make it work forever without human intervention ?
I want to know
  1. How IOT Product manufacturers solve these kind of problem
  2. Do I need to use Reset & supervisor IC?
  3. Do I need to turn off and On every hour using RTC?
Is it your own BLYNK server? If it's not, are they ok with data being sent so rapidly? I'm hard pressed to think of anything in an agricultural setting that needs such a refresh rate.
Put some debugging prints in there and see where it fails.
