How to make HTTPS POST to a server in internet?
Hello, before anything thanks for your time and for any help.
I have a server in raspberry PI running raspbian with LAMP (http://www.pihome.eu/2018/03/25/download-lamp-apache-php-7-0-and-mysql-mariadb-and-phpmyadmin-server-img-file/) that holds a PHP page in port 80.
I have an mkr1000 sending data successfully to the server via HTTP POST REQUEST (code shown below)
  Simple POST client for ArduinoHttpClient library
  Connects to server once every five seconds, sends a POST request
  and a request body
  created 14 Feb 2016
  by Tom Igoe
  this example is in the public domain
#include <ArduinoHttpClient.h>
#include <WiFi101.h>
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
/////// Wifi Settings ///////
char ssid[] = "MyUserVodafon";
char pass[] = "JKHAS765ShjhSHD";
//char serverAddress[] = "192.168.0.200";  // server address
char serverAddress[] = "worden-ipsubs-1267.dataplicity.io";  // server address
int port = 80;
WiFiClient wifi;
HttpClient client = HttpClient(wifi, serverAddress, port);
int status = WL_IDLE_STATUS;
String response;
int statusCode = 0;
    while ( status != WL_CONNECTED) {
      Serial.print("Attempting to connect to Network named: ");
      Serial.println(ssid);                   // print the network name (SSID);
      // Connect to WPA/WPA2 network:
      status = WiFi.begin(ssid, pass);
    // print the SSID of the network you're attached to:
    Serial.print("SSID: ");
    Serial.println(WiFi.SSID());
    // print your WiFi shield's IP address:
    IPAddress ip = WiFi.localIP();
    Serial.print("IP Address: ");
    Serial.println(ip);
    Serial.println("1) making POST request");
    String contentType = "application/x-www-form-urlencoded";
    String postData = "";
    // Variables SQL a chorizo para POST
    String CadenaValores = "/dht11.php?QuienSoy=ARDUINO";
    //Navegamos a la pagina (INSERT SQL, ver paginas PHP, ejem dht11.php)
    client.post(CadenaValores, contentType, postData);
    // read the status code and body of the response
    statusCode = client.responseStatusCode();
    response = client.responseBody();
    Serial.print("2) Status code: ");
    Serial.println(statusCode);
    Serial.print("3) RESPONSE: ");
    Serial.println(response);
    Serial.println("4) Fin loop");
    delay(5000);
It is working locally but the problem comes when trying to make a POST from outside the LAN with another mkr1000.
I have used (www.dataplicity.com) to control the raspberry PI, and also activated an option called wormhole that gives me a weird looking domain name like (https://nt-foxter-1181.dataplicity.io) that apparently let me do all I could in LAN with the IP number 192.168.0.200 but outside of the LAN .
Same code, same arduino, the only thing that I have changed in the second mkr1000 is the serverAddress,
//char serverAddress[] = "192.168.0.200"; // server address (ONLY FOR LAN)
char serverAddress[] = "chameleon-ipsubs-955.dataplicity.io"; // server address
and instead of getting Status Code 200, it shows Status Code 301
and instead of getting the echo from the response I usually get from the php page, it shows an error page.
<html>
<head><title>301 Moved Permanently</title></head>
<body bgcolor="white">
<center><h1>301 Moved Permanently</h1></center>
<hr><center>nginx</center>
</body>
</html>
I am really stuck and google results it's starting to only show purple results so I am running out of ideas and that is why I came here to ask for some help or hints.
Thanks a lot for any help.
Most Arduinos can not deal with the https protocol.
the keyword is SSL.
Consult your ISP also. Some of them (mine does) block incoming on port 80.
