How to make ir sensor not activate while something is on?
Hey all! Is it possible to make a sensor not be able to be triggered while something is going? I have a sketch where something needs to be going for a certain amount of time once the ir sensor is activated, however, if the ir is activated while the device is currently on than it makes it go for longer, which I do not want to happen. I am currently trying to use flags so that it can only activate when things are off, but nothing happens when the ir is activated. Code:
#include <VarSpeedServo.h>
VarSpeedServo servo;
# define PinThing1       12
# define PinThing2       13
boolean deviceOn = false;
enum states
  WAIT_FOR_TRIGGER,
  MOVE_TO_160_DEGREES,
  WAIT1,
  MOVE_TO_60_DEGREES,
  WAIT2,
  WAIT3,
  MOVE_TO_90_DEGREES,
const unsigned long wait1Period = 5000;
const unsigned long wait2Period = 5000;
const unsigned long wait3Period = 5000;
const unsigned long movementPeriod = 30000;
unsigned long currentTime;
unsigned long shortPeriodStartTime;
unsigned long movementPeriodStartTime;
byte currentState = WAIT_FOR_TRIGGER;
const byte triggerPin = 9;
const int servoPin = 8;
int pos = 90;
  pinMode(triggerPin, INPUT_PULLUP);
  Serial.println("waiting for trigger");
  servo.attach(8);
  digitalWrite (PinThing1,    LOW);
  pinMode(PinThing2, OUTPUT);
  pinMode(PinThing1, OUTPUT);
struct Timer {
  byte           pin;
  unsigned long  duration;
  bool           on;
Timer timers [] = {
  { PinThing1, 30000 },
  { PinThing2,    30000 }
#define N_TIMERS    (sizeof(timers)/sizeof(Timer))
  static unsigned long msecLst;
  unsigned long msec = millis ();
  // enable timed outputs
  if ((digitalRead(triggerPin) == LOW) && (deviceOn = false))  {
    deviceOn = true;
    msecLst = msec;
    for (unsigned n = 0; n < N_TIMERS; n++)  {
      timers [n].on = true;
      digitalWrite (timers [n].pin, HIGH);
  // turn off timed outputs when duration expired
  Timer *t = timers;
  for (unsigned n = 0; n < N_TIMERS; n++, t++)  {
    if (t->on && (msec - msecLst) > t->duration)  {
      digitalWrite (t->pin, LOW);
      deviceOn = false;
      t->on = false;
  currentTime = millis();
  switch (currentState)
    case WAIT_FOR_TRIGGER:
        currentState = MOVE_TO_160_DEGREES;
        movementPeriodStartTime = currentTime;
    case MOVE_TO_160_DEGREES:
      Serial.println("move to 160 degrees");
      servo.write(160, 10, true);
      shortPeriodStartTime = currentTime;
      currentState = WAIT1;
    case WAIT1:
      if (currentTime - shortPeriodStartTime >= wait1Period)
        currentState = MOVE_TO_60_DEGREES;
      checkMovementPeriod();
    case MOVE_TO_60_DEGREES:
      Serial.println("move to 60 degrees");
      servo.write(60, 10, true);
      currentState = WAIT3;
    case WAIT3:
      if (currentTime - shortPeriodStartTime >= wait3Period)
        currentState = MOVE_TO_90_DEGREES;
    case MOVE_TO_90_DEGREES:
      Serial.println("move to 90 degrees");
      servo.write(90, 10, true);
      currentState = WAIT2;
    case WAIT2:
void checkMovementPeriod()
  if (currentTime - movementPeriodStartTime >= movementPeriod)
    Serial.println("movement  period ended");
Thanks so much!
Then ignore the sensor during that time.
When something is going you set a disableFlag to true
When something stops going you set the disableFlag to false
When the a disableFlag is true, you never execute the sensor code.
(deviceOn = false)
OOPS
I thought I did something similar here and
here
How would i make the sensor code not able to run when the disable flag is true?
(deviceOn = false)
OOPS
lmao yeah is that what you were saying?
(deviceOn == false)
oh my god, rookie mistake lmao. I'll let you know if this doesn't work, thanks so much!
