How to Make LDR and PIR sensor response Time?
Hello everyone.
I looking for the solution about my small project.
So I decided to make motion and light sensor using PIR sensor and LDR.
I have the code which work perfectly. Here is it
#define LDR 0
#define PIR 2
#define LED 3
int pirState;
int ldrValue;
  //Serial.begin(9600);
  pinMode(LED, OUTPUT);
  pinMode(PIR, INPUT);
  digitalWrite(LED, LOW);
void loop(){
  ldrValue = analogRead(LDR);
  //Serial.print("Analog reading = ");
  //Serial.println(ldrValue);
  if (ldrValue <= 512) { // dark
    digitalWrite(LED, HIGH);
  else { // ldrValue > 512
    pirState = digitalRead(PIR);
    if (pirState == HIGH) {
      delay(5000);
    else { // pirState == LOW
my question is, how to make :
LED OFF when time is (example) 10pm - 3am but ON when there is a motion
You need to use an RTC module for keeping time, google for "arduino RTC module", you'll find a lot!
Cheers, ALe.
Hi, RTC info and how-to and code HERE:
ilguargua:
Cheers, ALe.
terryking228:
Thanks for respond.
But how to do it without RTC?
and
How is the code if I use RTC?
