How to make like the message send water level increase 50% then water level increase 70% then water level is in danger anyone know that help me please
#define trigPin1 A0
#define echoPin1 A1
long duration, distance;
char phone_no1[]="+60179487311";
char phone_no[]="+60120000015";
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
lcd.begin(16, 2);
lcd.setCursor(0, 1);
lcd.print("FLOOD DETECTION CONTROL ROOM..");
for (int positionCounter = 0; positionCounter < 29; positionCounter++)
lcd.scrollDisplayLeft();
Serial.begin (9600);
pinMode(trigPin1, OUTPUT);
pinMode(echoPin1, INPUT);
digitalWrite(trigPin1, LOW);
delayMicroseconds(2);
digitalWrite(trigPin1, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin1, HIGH);
distance = duration*0.034/2;
lcd.setCursor(0,0);
 lcd.print("WATER LEVEL:");
 lcd.print(distance);
 lcd.clear();
static int flag;
if ( distance<=5)
if (! flag) SendMessage();
flag = 1;
flag = 0;
void SendMessage()
Serial.println("AT+CMGF=1");
delay(2000);
Serial.print("AT+CSCA="");
Serial.print(phone_no);
Serial.write(0x22);
Serial.write(0x0D);
Serial.write(0x0A);
delay(3000);
Serial.print("AT+CMGS="");
Serial.print(phone_no1);
Serial.write(0x22);
Serial.write(0x0D);
Serial.write(0x0A);
delay(3000);
Serial.print("water level is in danger level");
Serial.println(char(26));
Please edit your post to add code tags and explain where the problem lies.
See the "How to get the best out of this forum" post.
This one:
Something that might not be mentioned there - preferably use ctrl-T to autoformat your code prior to uploading. Your indentation is non-existent.
Maybe start with absolute values rather than percentage change - just check the level and send an appropriate message if a limit has been exceeded.
If you must use percentage increase, what's the timeframe and how do you reset the clock?
Your topic has been moved to a more suitable location on the. Installation and Troubleshooting is not for advice on (nor for problems with) your project.
