How to make master node can receive and send package using rf24network?
I try to send sensor data from node 01 to node 00. but node 00 can not display data received. while from the child node, the data successfully sent.
I use arduino nano. and file RF24Network_config.h #define SERIAL_DEBUG_ROUTING I have un comment. is there something wrong with my code? please help me, i am confused my error where. because the try error does not show up
my code
transmiter
#include <RF24Network.h>
#include <RF24.h>
#include <DHT.h>
#include <SPI.h>
#define DHTPIN 2
#define DHTTYPE DHT11
DHT  dht(DHTPIN, DHTTYPE);
RF24 radio(7,8);                // nRF24L01(+) radio attached using Getting Started board
RF24Network network(radio);      // Network uses that radio
const uint16_t this_node = 01;    // Address of our node in Octal format ( 04,031, etc)
const unsigned long interval = 2000; //ms  // How often to send 'hello world to the other unit
unsigned long last_sent;
long packet_sent=1;
struct payload_t {                 // Structure of our payload
  long counter;
  float temperature;
  float humidity;
void setup(void)
  Serial.println("RF24Network/Transmiter/");
  SPI.begin();
  radio.begin();
  network.begin(/*channel*/ 90, /*node address*/ this_node);
  dht.begin();
void loop(void){
  network.update();                  // Check the network regularly
  unsigned long now = millis();    // If it's time to send a message, send it!
  if ( now - last_sent >= interval ){
    last_sent = now;
    float t = dht.readTemperature();
    float h = dht.readHumidity();
    payload_t payload = {packet_sent++,t,h};
    RF24NetworkHeader header(/*to node*/ 00);     // Send it to the base
    bool ok = network.write(header,&payload,sizeof(payload));
    if (ok){
      Serial.print("Packet : ");
      Serial.print(payload.counter);
      Serial.print(" Temperature : ");
      Serial.print(payload.temperature);
      Serial.print(" *C Humidity : ");
      Serial.print(payload.humidity);
      Serial.print(" %");
      Serial.println();
    else{
      Serial.println("Data Sensor Send Failed");
receiver
#include <RF24.h>
#include <SPI.h>
const uint16_t this_node = 00;    // Address of our node in Octal format ( 04,031, etc)
  long counter;
  float temperature;
  float humidity;
void setup(void)
  Serial.println("RF24Network/Receiver/");
  SPI.begin();
  radio.begin();
void loop(void){
  while (network.available() ) {     // Is there anything ready for us?
    RF24NetworkHeader header;
    payload_t payload;
    bool ok = network.read(header,&payload,sizeof(payload));
    if (ok){
      Serial.print(" % Dari Node : ");
      Serial.println(header.from_node);
    else{
      Serial.println("Data Sensor not receive");
my output
