How to make Menu on LCD using Rotary Encoder?
Hello,
I am struggling at making a Menu for LCD 16x2. I want to ask if someone has a solution on how to make Menu in easy way. Like is out there any library or anything that can help me make it.
Because my code is so messy and has so many lines for printing and clearing...
Also I forgot to mention that I'm using Rotary Encoder to move trough menu (screens).
What code would that be?
Do you currently have any flow charts or design schema for these menus?
Look here to start.
This is code:
LiquidCrystal_I2C lcd(0x27, 16, 2);
const int CLK = 10;
const int DT = 9;
const int SW = 3;
const int KEY_PIN = 2;
int key;
//const int RESSET_BTN = 5;
int resset;
int screen_delay = 1000;
bool selected_channel = false;
int lastCLKState;
int currentCLKState;
int DTState;
int SWState;
int screen = 1;
const int max_screens = 4;
bool selectedScreen = false;
int pressed = 0;
int counter = 0;
int value;
const int SHORT_PRESS_TIME = 500; // 500 milliseconds
int lastState = LOW;  // the previous state from the input pin
int currentState;     // the current reading from the input pin
unsigned long pressedTime  = 0;
unsigned long releasedTime = 0;
byte arrow[8] = {
  0b01000,
  0b01100,
  0b01110,
  0b01111,
  0b01110,
  0b01100,
  0b01000,
  0b00000
int key_insert = 0;
  lcd.init();
  lcd.backlight();
  lcd.setCursor(3, 0);
  lcd.print("Fireworks");
  lcd.setCursor(4, 1);
  lcd.print("Igniter");
  lcd.createChar(0, arrow);
  delay(2000);
  lcd.clear();
  checkScreen(screen);
  pinMode(CLK, INPUT);
  pinMode(DT, INPUT);
  pinMode(SW, INPUT_PULLUP);
  pinMode(KEY_PIN, INPUT_PULLUP);
  lastCLKState = digitalRead(CLK);
void checkScreen(int sc) {
  switch (sc) {
    case 1:
      lcd.clear();
      lcd.setCursor(2, 0);
      lcd.print("Node 1");
      lcd.setCursor(0, 0);
      lcd.write(byte(0));
      lcd.setCursor(2, 1);
      lcd.print("Node 2");
    case 2:
      lcd.clear();
      lcd.setCursor(0, 1);
      lcd.write(byte(0));
    case 3:
      lcd.clear();
      lcd.print("Node 3");
      lcd.write(byte(0));
      lcd.print("Node 4");
    case 4:
      lcd.clear();
      lcd.write(byte(0));
    default: screen = 4;
void selectScreen() {
  lcd.clear();
  lcd.print("Select Channel:");
  lcd.print("CH1");
  lcd.print("CH2");
  lcd.setCursor(8, 1);
  lcd.print("CH3");
  lcd.setCursor(12, 1);
  lcd.print("CH4");
void controll_servo(int sc) {
  switch (sc) {
    case 1:
      lcd.clear();
      lcd.print("Servo 1");
      lcd.write(byte(0));
      lcd.print("Servo 2");
    case 2:
      lcd.clear();
      lcd.write(byte(0));
    default:
      sc = 2;
void selectChannel(int value) {
  if (value < 100) {          //Ch1
    Serial.println("CH1");
    controll_servo(screen);
    pressed = 0;
  } else if (value == 513) {    //Ch2
    Serial.println("CH2");
    pressed = 0;
  } else if (value == 509 || value == 510) {    //Ch3
    Serial.println("CH3");
    pressed = 0;
  } else if (value == 512) {    //Ch4
    Serial.println("CH4");
    pressed = 0;
  key = digitalRead(KEY_PIN);
  if (key == HIGH) {
    digitalWrite(LED_BUILTIN, HIGH);
    lcd.clear();
    lcd.setCursor(4, 0);
    lcd.print("Key");
    lcd.setCursor(1, 1);
    lcd.print("Required!");
    digitalWrite(LED_BUILTIN, LOW);
    delay(250);
    lcd.clear();
    lcd.setCursor(8, 0);
    lcd.print("Key");
    lcd.setCursor(5, 1);
    key_insert = 0;
  else if (key == LOW) {
    if (key_insert == 0) {
      key_insert = 1;
    currentCLKState = digitalRead(CLK);
    if (currentCLKState != lastCLKState && currentCLKState == 1) {
      DTState = digitalRead(DT);
      if (DTState != currentCLKState) { // CW
        if (!selectedScreen) {
          if (screen < max_screens) screen++;
          if (selected_channel) controll_servo(screen);
        } else return;
      } else {                          // CCW
          if (screen > 1) screen--;
    SWState = digitalRead(SW);
    if (lastState == HIGH && SWState == LOW)       // button is pressed
      pressedTime = millis();
    else if (lastState == LOW && SWState == HIGH) { // button is released
      releasedTime = millis();
      long pressDuration = releasedTime - pressedTime;
      if ( pressDuration < SHORT_PRESS_TIME ) {
        pressed = 1;
        selectScreen();
        selectedScreen = true;
        while (pressed == 1) {
          value = analogRead(A0);
          selectChannel(value);
          delay(250);
          delay(250);
        lcd.clear();
        pressed = 0;
        screen = 1;
    // save the the last state
    lastState = SWState;
    lastCLKState = currentCLKState;
Nope, just text.
You could accomplish a lot just by factoring your code. How much is different between these two cases? Only the things that are different should be in the cases, the rest should be outside the switch statement.
I know the code is not perfect and has a lot to work, but my question is like is there any easier way to make menu, like some library or anything...
used an encoder in the Uno Logic Tester..
has a small menu, yes/no prompts..
have fun.. ~q
I have a library (MD_Menu or load from the IDE library manager) that I wrote for this type of display (2 line LCD module) and the example code uses a rotary encoder as one of the options for the user input. Wrote a blog post about it here.
If you don't evolve and improve as a programmer, you may end up in as much of a mess with a library, as without one. I'm not pointing the finger at you, specifically, it's generally true. Libraries often require study and the correct usage of the interface, which you, as the user, don't control.
That is why I asked you if you have a written plan. Whether you are coding it yourself, or passing tasks to a library, you need to have a clear road map.
And, the clarity and efficiency of your code won't necessarily be improved by using the library. For example, you could just as easily fall into the trap of redundancy like the example I quoted, with a library as without.
Thank You, I'll check it.
