How to make motor take single coil full step, dual coil full step and half step?
Using a ULN2003 to drive a stepper motor that takes input from the Arduino mega to a stepper motor. The menu options on whether the motor takes single coil full steps (mode 1), dual coil full steps (mode 2), or half steps (mode 3). I have a feeling I have the wrong idea about making the motor go full step vs half step. Apparently half step is supposed to be the combination of both single and dual coil fullstep. How would I accomplish this? What is the difference between half step, dual coil full step and single coil full step?
#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 4;
char hexaKeys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {9, 8, 7, 6};
byte colPins[COLS] = {5, 4, 3, 2};
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
#define STEPPER_PIN_1 46
#define STEPPER_PIN_2 47
#define STEPPER_PIN_3 48
#define STEPPER_PIN_4 49
int step_number = 0;
bool motorDirec = true; // controls direction of motor
int rate = 100;
char userInput = 'Z';
int maxSteps = 3;
int mode = 1;
  pinMode(STEPPER_PIN_1, OUTPUT);
  pinMode(STEPPER_PIN_2, OUTPUT);
  pinMode(STEPPER_PIN_3, OUTPUT);
  pinMode(STEPPER_PIN_4, OUTPUT);
  if( mode == 1)
    singleStep();
    delay(rate);
  else if( mode == 2)
    dualStep();
    delay(rate);
  else if(mode == 3)
    singleStep();
    delay(rate);
    dualStep();
  char customKey = customKeypad.getKey();
  if(customKey)
    userInput = customKey;
    menu(userInput); //user selects how they want to manipulate stepper motor
void singleStep() //single coil full step
   if(motorDirec == true)
    switch(step_number)
      case 0:
        digitalWrite(STEPPER_PIN_1, HIGH);
        digitalWrite(STEPPER_PIN_2, LOW);
        digitalWrite(STEPPER_PIN_3, LOW);
        digitalWrite(STEPPER_PIN_4, LOW);
      case 1:
        digitalWrite(STEPPER_PIN_1, LOW);
        digitalWrite(STEPPER_PIN_2, HIGH);
      case 2:
        digitalWrite(STEPPER_PIN_3, HIGH);
      case 3:
    switch(step_number)
      case 0:
        digitalWrite(STEPPER_PIN_4, HIGH);
      case 1:
      case 2:
      case 3:
  step_number++;
  if(step_number > 3)
    step_number = 0;
void dualStep() //Dual coil full step
    switch(step_number)
      case 0:
      case 1:
      case 2:
      case 3:
      case 4:
      case 5:
      case 6:
      case 7:
    switch(step_number)
      case 0:
      case 1:
      case 2:
      case 3:
      case 4:
      case 5:
      case 6:
      case 7:
  step_number++;
  if(step_number > 7)
    step_number = 0;
void menu(char userInput) // menu allows for appropriate selections
  switch(userInput)
    case 'A':
      motorDirec = true;
      Serial.println("Changing to clock-wise direction");
    case 'B':
      motorDirec = false;
      Serial.println("Chaning to counter clock-wise direction");
    case 'C':
      if(rate < 1000)
        rate++;
        Serial.println("Decreasing number of steps per second!!");
        Serial.println("1000 limit has been reached!!!!");
    case 'D':
      if(rate > 1)
        rate--;
        Serial.println("Increasing number of steps per second!");
        Serial.println("1 limit has been reached!!!!");
    case '1':
      Serial.println("Now entering mode 1");
      mode = 1;
    case '2':
      Serial.println("Now entering mode 2");
      mode = 2;
    case '3':
      Serial.println("Now entering mode 3");
      mode = 3;
Where did you find these modes described?
Your code does not make anything meaningful. singleStep() and dualStep() by themselves only differ in stepper speed. In combination the step_number is reset by singleStep() so that only half of the dualStep() code is used.
You better start from this page.
Actually, I figured it out. I just adjusted my cases to match the excitement states on the diagram from the website you gave me. Using a library does not give me as much control as I want from the stepper motor.
Here is now what I have below........
#include <Keypad.h>
int step_number2 = 0;
int step_number3 = 0;
int rate = 100;
int maxSteps = 3;
int mode = 1;
  if( mode == 1)
    singleCoil();
    delay(rate);
  else if( mode == 2)
    doubleCoil();
    delay(rate);
  else if(mode == 3)
    halfStep();
    delay(rate);
  if(customKey)
    menu(userInput);
// Code block for single coil full step
void singleCoil()
    switch(step_number)
      case 0:
      case 1:
      case 2:
      case 3:
    switch(step_number)
      case 0:
      case 1:
      case 2:
      case 3:
  step_number++;
  if(step_number > 3)
    step_number = 0;
//Code for double coil full step
void doubleCoil()
    switch(step_number2)
      case 0:
      case 1:
      case 2:
      case 3:
      case 0:
      case 1:
      case 2:
      case 3:
  step_number2++;
  if(step_number2 > 3)
    step_number2 = 0;
//Code for half step
void halfStep()
    switch(step_number3)
      case 0:
      case 1:
      case 2:
      case 3:
      case 4:
      case 5:
      case 6:
      case 7:
      case 0:
      case 1:
      case 2:
      case 3:
      case 4:
      case 5:
      case 6:
      case 7:
  step_number3++;
  if(step_number3 > 7)
    step_number3 = 0;
  switch(userInput)
    case 'A':
      motorDirec = true;
      //loop();
    case 'B':
      motorDirec = false;
      //loop();
    case 'C':
      if(rate < 1000)
        rate++;
    case 'D':
      if(rate > 1)
        rate--;
    case '1':
      mode = 1;
    case '2':
      mode = 2;
    case '3':
      mode = 3;
