Hi all,
My alarm system didn't support remote control (arm/disarm), I would like to know if my arduino can emulate a pressure on key fob button ?
Thanks.
Hi all,
Thanks.
Attach a servo to it. No need to emulate anything.
It should be a quite tricky to make the servo push exactly to te right position, no ?
Raspoutitsa:
No. A jig would hold the remote and the servo in the correct relationship.
Raspoutitsa,
Give Paul a cookie, and then try to tell us exactly what it is you want the Arduino to do.
I suspect that you want the arduino to receive a signal from the keyfob transmitter, decode said signal, and tell the alarm to do something?? If so, and you want helpful answers, we need a lot more information.
What is the frequency and transmission protocol of the key fob.
what/how to tell the alarm to arm/disarm (open/close a switch, send a code, tap it on the shoulder??)
Things like that, and a lot more...
I suspect you want something like this
http://www.lightobject.com/4CH-RF-Remote-Control-TxRx-Kit-module-P110.aspx
where you can press a button and the Arduino sees one of 4 inputs go high and acts on it.
Or this, where no Arduino is needed, the car reacts to the relays being energized.
http://www.lightobject.com/4CH-RF-Wireless-Remote-Control-1527-TxRx-Kit-Metal-case-P351.aspx
Thanks for yours replies !
Due to security protocol (multiple frequencies + encryption), Arduino cannot control my alarm system directly or it's too complex for me !!!
My keyfob is like that :
I just want to find a way to disarm/arm my system remotely.
Security levels of my control panel are very strong, it's for that reason that I think the best way do that is to use original keyfob. Paul are right, I just want to find a way to map arduino and keyfob.
Use the relay remote to close the button contacts on Lock/Unlock/I/II remote.
Guys, I have got the solution !
Below you will find mine keyfob’s anatomy
It’s quite simple, I just have to put an arduino between the printed circuit tracks, that’s it.
To contact my arduino remotely, I have two options :
-I have cctv server (ok I am little bit paranoid) I can code a small script that activate my arduino when a specific email come in.
I keep you in touch
Hi all,
I have some news but before let me resume what I want to do.
I have installed an alarm system with outdoor detector, all works great but sometimes (very rarely) I have false alarms.
Even if my system is relatively modern and sophistaced I am unable to disarm it remotely.
And for it arduino can help me !
When I have dissassembled my keyfob I have noticed that If I place my arduino between these electrics tracks
and with this script :
int AlarmPin = 13;
pinMode(AlarmPin , OUTPUT);
digitalWrite(AlarmPin , HIGH);
digitalWrite(AlarmPin , LOW);
I can disarm my system.
But when the arduino is powered off contact between these tracks are always on, to resolve that, I have to put a relay between arduino and keyfob.
That model could work for my project ?
next steps :
Read voltage of the led in order to get the status of my system (arm / disarm)
Create an Android application
Thanks
