Hi there,
I've got a question on variables. I'm using the following code for my RFID-Shield on Arduino:
RFID Eval 13.56MHz Shield example sketch v10
Aaron Weiss, aaron at sparkfun dot com
OSHW license: http://freedomdefined.org/OSHW
works with 13.56MHz MiFare 1k tags
Based on hardware v13:
D7 -> RFID RX
D8 -> RFID TX
D9 -> XBee TX
D10 -> XBee RX
Note: RFID Reset attached to D13 (aka status LED)
Note: be sure include the SoftwareSerial lib, http://arduiniana.org/libraries/newsoftserial/
Usage: Sketch prints 'Start' and waits for a tag. When a tag is in range, the shield reads the tag,
blinks the 'Found' LED and prints the serial number of the tag to the serial port
and the XBee port.
06/04/2013 - Modified for compatibility with Arudino 1.0. Seb Madgwick.
#include <SoftwareSerial.h>
SoftwareSerial rfid(7, 8);
SoftwareSerial xbee(10, 9);
//Prototypes
void check_for_notag(void);
void halt(void);
void parse(void);
void print_serial(void);
void read_serial(void);
void seek(void);
void set_flag(void);
//Global var
int flag = 0;
int Str1[11];
//INIT
Serial.println("Start");
// set the data rate for the SoftwareSerial ports
xbee.begin(9600);
rfid.begin(19200);
delay(10);
halt();
//MAIN
read_serial();
void check_for_notag()
seek();
delay(10);
parse();
set_flag();
if(flag = 1){
seek();
delay(10);
parse();
void halt()
//Halt tag
rfid.write((uint8_t)255);
rfid.write((uint8_t)0);
rfid.write((uint8_t)1);
rfid.write((uint8_t)147);
rfid.write((uint8_t)148);
void parse()
while(rfid.available()){
if(rfid.read() == 255){
for(int i=1;i<11;i++){
Str1[i]= rfid.read();
void print_serial()
if(flag == 1){
//print to serial port
Serial.print(Str1[8], HEX);
Serial.print(Str1[7], HEX);
Serial.print(Str1[6], HEX);
Serial.print(Str1[5], HEX);
delay(100);
//check_for_notag();
void read_serial()
seek();
delay(10);
parse();
set_flag();
print_serial();
delay(100);
void seek()
//search for RFID tag
rfid.write((uint8_t)130);
rfid.write((uint8_t)131);
delay(10);
void set_flag()
if(Str1[2] == 6){
flag++;
if(Str1[2] == 2){
flag = 0;
Now I'd like to make one new variable tagid which should consist of those variables in the if-part that are printed to the Serial Monitor:
void print_serial()
if(flag == 1){
delay(100);
How do I have to do that?
Yours
arduino2013
