#include <Wire.h>
#include "RTClib.h"
#include <SPI.h>
#include <SD.h>
RTC_DS1307 RTC;
File myFile;
void setup(){
Serial.begin(38400);
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
Wire.begin();
RTC.begin();
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
RTC.adjust(DateTime(F(DATE), F(TIME)));
cli();//stop interrupts
//set timer1 interrupt at 1Hz
TCCR1A = 0;// set entire TCCR1A register to 0
TCCR1B = 0;// same for TCCR1B
TCNT1 = 0;//initialize counter value to 0
// set compare match register for 1hz increments
OCR1A = 15624;// = (1610^6) / (11024) - 1 (must be <65536)
//OCR1A = 3124;// = (1610^6) / (11024) - 1 (must be <65536)
// turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS12 and CS10 bits for 1024 prescaler
TCCR1B |= (1 << CS12) | (1 << CS10);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A);
sei();//allow interrupts
//cli();
}//end setup
ISR(TIMER1_COMPA_vect)
{//timer1 interrupt 1Hz toggles pin 13 (LED)
//generates pulse wave of frequency 1Hz/2 = 0.5kHz (takes two cycles for full wave- toggle high then toggle low)
int blueToothVal=0;
if(Serial.available())//if there is data being recieved
blueToothVal=0;
blueToothVal=Serial.read(); //read it
if(blueToothVal=='1')
digitalWrite(5,HIGH);
void loop();
DateTime now = RTC.now();
myFile = SD.open("test1.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test1.txt...");
myFile.print(now.year(), DEC);
myFile.print('/');
myFile.print(now.month(), DEC);
myFile.print('/');
myFile.print(now.day(), DEC);
myFile.print(' ');
myFile.print(now.hour(), DEC);
myFile.print(':');
myFile.print(now.minute(), DEC);
myFile.print(':');
myFile.print(now.second(), DEC);
myFile.println();
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
why rtc is not work in interrupt, help how to change a code.
