How to make SD card read/write faster?
Ok, so I’ve gone to this website and learned to avoid using txt/CSV files for data logging because it is significantly faster. But now I have a new issue. Essentially, what I am trying to do is put two variables in an SD card, but these variable are changing over time so in the “array terminology” I will have 1000 rows(this is enough sampling) and 2 columns(the two variables).
My Idea
I think I want to have an array of structs and be able to read each of them from the sd card. But why would I need to create 2D arrays if all the data is stored in the SD card anyway, right? When I’m done, I will take this data and make the Arduino print them out on an LCD display**
Both pieces of my code below are what I have so far. Please check both sketches.
This code counts up by 1 every second, starting at 1. This code works, but it doesn’t log the data into the sd card. It should send the following to the serial monitor: "1 2 3 4 5…"
#include <SD.h>
#include <SPI.h>
const int chipSelect = 10;
File dataFile;
struct datastore {
  uint8_t num;
  Serial.print("Initializing SD card...");
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    return;
  Serial.println("card initialized.");
  if (SD.exists("1.dat"))
    SD.remove("1.dat");
  dataFile = SD.open("1.dat", FILE_WRITE);
int i = 0;
  struct datastore myData;
  myData.num = 1 + i;
  Serial.println(myData.num);
  i++;
  dataFile.write((const uint8_t *)&myData, sizeof(myData));
This code prints out each collected number. Obviously, this code is a fail, but its like pseudo
#include <SD.h>
#include <SPI.h>
File dataFile;
struct datastore {
  uint8_t num;
    return;
  dataFile = SD.open("1.dat", FILE_READ);
  if (dataFile) {
    dataFile.read((uint8_t*)&myData, sizeof(myData));
    Serial.println((int)myData.num);
    delay(50);
  else{
    Serial.println("can't open");
The goal is to make the second code print out the numbers in the serial monitor: "1 2 3 4 5…"
Force FAT update with 'flush' og 'close' the file.
That is NOT at all obvious.
Not closing the file on the write pass is NOT good. That can lead to corrupt, unrecoverable files.
Why are you using a struct to wrap one int? What is the advantage in that?
