How to make serial.print into a varibale
Below is code we found from this site that works great. How ever we are having difficulty taking the parsed GPS and putting the LAT and LONG into a variable format. Any ideas or code out there that could help us? Also does the serial need to be printed each time or can we omit it to save space?
  if(bien==6){               // If yes, continue and process the data
         for (int i=0;i<300;i++){
           if (linea[i]==','){    // check for the position of the  "," separator
             // note: again, there is a potential buffer overflow here!
             indices[cont]=i;
             cont++;
           if (linea[i]=='*'){    // ... and the "*"
             indices[12]=i;
             cont++;
         Serial.println("");      // ... and write to the serial port
         Serial.println("");
         Serial.println("---------------");
         for (int i=0;i<12;i++){
           switch(i){
             //case 0 :Serial.print("Time in UTC (HhMmSs): ");break;
             case 1 :Serial.print("Status (A=OK,V=KO): ");break;
             case 2 :Serial.print("Latitude: ");break;
             case 3 :Serial.print("Direction (N/S): ");break;
             case 4 :Serial.print("Longitude: ");break;
             case 5 :Serial.print("Direction (E/W): ");break;
             case 6 :Serial.print("Velocity in knots: ");break;
             //case 7 :Serial.print("Heading in degrees: ");break;
             //case 8 :Serial.print("Date UTC (DdMmAa): ");break;
             //case 9 :Serial.print("Magnetic degrees: ");break;
             //case 10 :Serial.print("(E/W): ");break;
            // case 11 :Serial.print("Mode: ");break;
             //case 12 :Serial.print("Checksum: ");break;
Omit what?
Have you considered sprintf?
AWOL:
Omit what?
I have been messing around with it but have been unsuccessful in implementing it. I do not know where I would put it and how to integrate it into the different cases or the serial.prints.
Where is that code?
Basically, like this:
      char variable = Serial.read();
replace the char with your desired datatype.
clarkmcc:
Can I do something like this?
float latitude;
latitude=sprintf(Serial.print("Latitude: "));break;
Well you can do it but it won't do what you think.
Here is how Adafruit does it in their GPS library
(Just a snippet of the relevant code)
  if (strstr(nmea, "$GPGGA")) {
    // found GGA
    char *p = nmea;
    // get time
    p = strchr(p, ',')+1;
    float timef = atof(p);
    uint32_t time = timef;
    hour = time / 10000;
    minute = (time % 10000) / 100;
    seconds = (time % 100);
    milliseconds = fmod(timef, 1.0) * 1000;
    // parse out latitude
    latitude = atof(p);
    if (p[0] == 'N') lat = 'N';
    else if (p[0] == 'S') lat = 'S';
    else if (p[0] == ',') lat = 0;
    else return false;
    // parse out longitude
    longitude = atof(p);
    if (p[0] == 'W') lon = 'W';
    else if (p[0] == 'E') lon = 'E';
    else if (p[0] == ',') lon = 0;
    else return false;
    fixquality = atoi(p);
    satellites = atoi(p);
    HDOP = atof(p);
    altitude = atof(p);
    geoidheight = atof(p);
    return true;
mrburnette:
https://github.com/adafruit/Adafruit-GPS-Library
// found GGA
    char *p = nmea;
    // get time
    p = strchr(p, ‘,’)+1;
    latitude = atof(p);
    if (p[0] == ‘N’) lat = ‘N’;
    else if (p[0] == ‘S’) lat = ‘S’;
    else if (p[0] == ‘,’) lat = 0;
    else return false;
    if (p[0] == ‘W’) lon = ‘W’;
    else if (p[0] == ‘E’) lon = ‘E’;
    else if (p[0] == ‘,’) lon = 0;
    else return false;
    HDOP = atof(p);
    altitude = atof(p);
    return true;
Thank you!
Grumpy_Mike:
how would I go about doing it what I think? Thanks.
hlhowns:
Grumpy_Mike:
telepathy features have not yet been enabled on this forum.
are you thinking about Strings ?
do you want to have a fixed "sentence" made as a variable to be called whenever you need it ?
hlhowns:
float latitude;
well:-
char latitude[] = "Latitude: ";
Would do it.
