How to make servo rotate completely?
I wrote some code that makes my Servo motor rotate whenever the photoresistor gets dark. I held my photoresistor up to a white computer screen and periodically made the screen black. When it sensed black, the servo would move, but when I flash the black color very quickly, (for less than a second) The servo would rotate, but just barely. How do I make it so that the servo rotates completely to how much it should and then go back when it sees white? I am including my current code below.
[code]
#include <Servo.h>
Servo myservo;
int sensorPin = A0;
int sensorValue = 0;
int val;
  myservo.attach(2);
  myservo.write(80);
  sensorValue = (analogRead(sensorPin));
  if (sensorValue < 650) {
    // cactus
    val = 130;
  else {
    //no cactus
    val =  80;
    myservo.write(val);
    delay(0);
  Serial.println(sensorValue); //debug
  myservo.write(val);
  delay(15);
[/code]
Servos take time to move. A typical servo is specified at 300ms to move 60 degrees (unloaded). Is the servo loaded?
Give the servo enough time to move. Introduce a bit of delay when it senses the cactus. Use millis() for the timing, not delay().
Non-blocking timing tutorials:
Several things at a time.
Beginner's guide to millis().
Blink without delay().
Or you could try VarSpeedServo.h instead of Servo.h. That has a 'wait' parameter on the write() that should allow the servo complete the move before continuing. I've used that library a few times but not for that purpose so you'll have to try it yourself to see if it does what you need.
Steve
