How to make servo stop and return to start position before sequence finishes
I've been trying to figure this out for awhile and I can't seem to get it. I want my servo to return to zero if the button is released and not complete the sequence or if anytime during the sequence the button is released it will return to zero. Right now the program I have, when I press the button, the servo rises to 90 degrees at a variable rate, then continues on to 180 and rocks back and fourth. Once the button is released it goes back to zero. All is good, but I want it to go back to zero immediately if at any time the button is released. It always wants to complete at least one cycle. Does anyone know how to get this to work? Any help would be appreciated.
Here is the code:
#include <VarSpeedServo.h>
VarSpeedServo myservo; // create servo object to control a servo
int pos = 0; // variable to store the servo position
const int buttonPin = 12; //sets pin 2 as button
const int buttonPin2 = 13; //sets pin 3 as button
const int ledPin = 1; // sets pin 13 as LED for testing purposes
int buttonState = 0; //sets button 1 as off
int buttonState2 = 0; // sets button 2 as off
myservo.attach(9); // attaches the servo on pin 9 to the servo object
pinMode (buttonPin, INPUT); // sets button as input
pinMode (ledPin, OUTPUT); // sets led as output
myservo.write(0,255,true);
delay (10);
buttonState = digitalRead(buttonPin);
buttonState2 = digitalRead(buttonPin2);
if (buttonState == HIGH)
digitalWrite(ledPin, HIGH);
myservo.write(90,10,true);
delay(50);
for(pos = 90; pos <= 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=90; pos-=1) // goes from 180 degrees to 0 degrees
else {
digitalWrite(ledPin, LOW);
delay(50);
myservo.write(0,10,true);
delay(50);
Since the servo movement all happens inside a for loop, the button isn't examined until the movement is finished....
You probably want to read the button inside the for and break out to do your reset if necessary.
