My project is a robotic arm. I've been wanting to make the arm's movements more efficient by making the joints move at the same time instead of one at a time. However, I can't figure out how to do that with VarSpeedServo.
Below is the current code. It's a bit long and messy as it was just to test out VarSpeedServo.h
The function of the code is to pick and place an object.
//include custom library to control servos
#include <VarSpeedServo.h>
//Create servo variable
VarSpeedServo servoBase;
VarSpeedServo servoArm1;
VarSpeedServo servoArm2;
VarSpeedServo servoArmGrip;
VarSpeedServo servoGrip;
Serial.begin(9600); // set the serial monitor data rate
// assign pins to each servo motor
servoBase.attach(3);
servoArm1.attach(5);
servoArm2.attach(6);
servoArmGrip.attach(9);
servoGrip.attach(10);
Serial.println("output initialized");
armDefault();
//SPEED SETTINGS
const int SPEED1 = 15; //speed one is default speed.
const int SPEED2 = 30; //speed faster is slower and is for movements that don't require more precision.
//CREATE FUNCTIONS
void armDefault() // sets the arm to the default position
//zero out the base motor
servoBase.write(0,SPEED1, true);
//set servo arms to default position
servoArm1.write(120,SPEED1,true);
servoArm2.write(100,SPEED1,true);
servoArmGrip.write(120,SPEED1,true);
delay(100);
servoGrip.write(0);
delay(100);
servoGrip.detach();
void armRetract() //arm retract is similiar to default, however it does not include the gripper
servoArm1.write(68,SPEED1, true); // set to 68 instead of 65 as the angle for some reason changes slightly, this is just to account for it.
void armExtend(int SPEED1, int SPEED2) //this function serves to extend the arm
servoArm1.write(65,SPEED2,true); //the servo is set to 65 instead of 90 due to hardware issues. 65 = 90 degrees in this case
servoArm2.write(140,SPEED2,true);
servoArm1.write(30,SPEED1,true);
//Claw functions
void clawClose() // activates servo motor responsible for closing claw
delay(200);
servoGrip.write(180);
delay(100);
servoGrip.detach();
void clawOpen() //activates servo motor responsible for opening claw
delay(100);
servoGrip.write(0);
delay(100);
servoGrip.detach();
//Swivel functions
void SWIVEL0()
servoBase.write(0,SPEED2,true);
void SWIVEL90()
servoBase.write(90,SPEED2,true);
void SWIVEL180()
servoBase.write(180,SPEED2,true);
SWIVEL180();
armExtend(15, 30); //integers in brackets represent speed
clawClose();
armRetract();
//end block
SWIVEL90();
armExtend(15, 30);
clawOpen();
armRetract();
SWIVEL180();
armExtend(15, 30);
clawClose();
armRetract();
SWIVEL0();
armExtend(15, 30);
clawOpen();
armRetract();
