I want to create a setpoint for the temperature sensor by using two push buttons, 1 push button for increment, another push button for decrement. For example, now the temperature is 24 Celsius degree. I want to set the temperature to 20 Celsius degree, where after reaching the desired temperature the control valve will receive an order. the question is how to make a program to change the value with pushbutton? or create a setpoint with a pushbutton?
Hello
You may take a view into the IDE examples as start point.
Once you have understood what's required to handle a button and how to wire it to your arduino, there are many button libraries to make your life easier.
thankyouu, Previously I understood the wiring, and the system I made, but I'm just confused about changing the constant to something that can be changed at any time
Here is example code for changing a setpoint with up and a down pushbutton switches.
The circuit:
- pushbutton attached to pin 2 from ground
- the internal pullup on pin 2 is enabled
- pushbutton attached to pin 3 from ground
- the internal pullup on pin 3 is enabled
// these constants won't change:
const byte upButtonPin = 2;
const byte downButtonPin = 3;
// Variables will change:
int setpoint = 0;
bool setpointChanged = false;
// initialize the button pins as a input with internal pullup:
pinMode(upButtonPin, INPUT_PULLUP);
pinMode(downButtonPin, INPUT_PULLUP);
// initialize serial communication:
Serial.println("setpoint change with 2 buttons example\n\n");
checkUpButton();
checkDownButton();
if (setpointChanged == true)
Serial.print("new setpoint = ");
Serial.println(setpoint);
void checkUpButton()
boolean buttonState = 0; // current state of the button
static boolean lastButtonState = 0; // previous state of the button
static unsigned long timer = 0;
unsigned long interval = 50; // check 20 times a second
if (millis() - timer >= interval)
timer = millis();
// read the pushbutton input pin:
buttonState = digitalRead(upButtonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState)
// if the state has changed, increment the counter
if (buttonState == LOW)
// if the current state is LOW then the button went from off to on:
setpoint++;
setpointChanged = true;
// save the current state as the last state, for next time through the loop
lastButtonState = buttonState;
void checkDownButton()
timer = millis();
buttonState = digitalRead(downButtonPin);
setpoint--;
Start by not declaring the setpoint variable as a const
Hello
I´m a great friend of array´s and objects.
//BLOCK COMMENT
// https://forum.arduino.cc/t/how-to-make-setpoint-with-push-button/893568
#define ProjectName "how to make setpoint with push button"
// CONSTANT DEFINITION
// you may need to change these constants to your hardware
const byte Input_[] {A0, A1};
const byte Output_[] {2};
// VARIABLE DECLARATION
enum {One, Two, Three, Four};
enum {Value, Min, Max, Trigger};
int setPoint[] {0, 0, 30, 24};
enum {Up, Down};
struct BUTTON { // declare an object
int name; // member name
byte pin; // pin address
bool state; // and state
} buttons [] { // make two button objects
{Up, Input_[One], 1}, // state =1 due to pinMode = INPUT_PULLUP
{Down, Input_[Two], 1},
// FUNCTIONS
Serial.println(F("."));
Serial.print(F("File : ")), Serial.println(__FILE__);
Serial.print(F("Date : ")), Serial.println(__DATE__);
Serial.print(F("Project: ")), Serial.println(ProjectName);
pinMode (LED_BUILTIN, OUTPUT);
for (auto Input : Input_) pinMode(Input, INPUT_PULLUP);
for (auto Output : Output_) pinMode(Output, OUTPUT);
void loop () {
unsigned long currentTime = millis();
digitalWrite(LED_BUILTIN, (currentTime / 500) % 2); // make heartbeat
for (auto &button : buttons) {
bool stateNew = digitalRead(button.pin); // read state
if (button.state != stateNew) { // state changed ?
button.state = stateNew; // save new state
if (!stateNew) { // is button pressed ?
switch (button.name) { // which button is pressed ?
case Up:
setPoint[Value]++;
if (setPoint[Value] > setPoint[Max]) setPoint[Value] = setPoint[Max];
case Down:
setPoint[Value]--;
if (setPoint[Value] < setPoint[Min]) setPoint[Value] = setPoint[Min];
digitalWrite(Output_[One], setPoint[Value] >= setPoint[Trigger]); // male output
Serial.println(setPoint[Value]);
delay (20); // bad delay to debounce :)
Have fun and enjoy the coding
Thankyouuu!!!
