Hi! I am not a programmer and having a hard time trying to make my stepper motor move the way I need.
I have two tact switches connected to Pins 5 and 6 called button1 and button2. When clicked they are supposed to make motor move to some places and go back to starting position. It works fine but I need to change this code to make my motor accelerate when starting and decelerate before reaching the end point.
I would appreciate any help.
This is my code:
// define the pins
#define IN1 8
#define IN2 9
#define IN3 10
#define IN4 11
#define button1 5
#define button2 6
// define how many cycles to a full rotation
#define CYCLES_PER_ROTATION 512
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT_PULLUP);
while (digitalRead(button1) == LOW) {
// make the stepper do 0.5 rotations CW
turns(0.5);
// make the stepper do 1.5 rotations CCW
turns(-1.5);
turns(1.5);
turns(-0.5);
while (digitalRead(button2) == LOW) {
turns(0.5);
turns(0.25);
delay(200);
turns(0.25);
delay(200);
turns(-1.0);
void turns(float rotations)
// if the rotation count is -ve then it is CCW
Serial.print("Turning : ");
Serial.print(rotations);
Serial.println(" rotations");
bool clockwise = rotations > 0;
Serial.print("Clockwise = ");
Serial.println(clockwise);
// calculate how many cycles the stepper will have to make
int cycles = rotations * CYCLES_PER_ROTATION;
// force the cycle count to be positive
cycles = abs(cycles);
Serial.print("That is ");
Serial.print(cycles);
Serial.print(" Cycles ");
// only move if the user specifed an actual movement
if(rotations != 0)
if (clockwise)
Serial.println("Clockwise");
// for each cycle
for (int x=0; x<cycles; x++)
// for each phase
for(int y=0; y<8; y++)
// go to phase y
phaseSelect(y);
// pause so the stepper has time to react
delay(1);
Serial.println("Counter Clockwise");
// for each cycle
// for each phase (backwards for CCW rotation)
for(int y=7; y>=0; y--)
// go to phase y
phaseSelect(y);
delay(1);
// go to the default state (all poles off) when finished
phaseSelect(8);
Serial.println("Done");
void phaseSelect(int phase)
switch(phase){
case 0:
digitalWrite(IN1, LOW);
digitalWrite(IN2, LOW);
digitalWrite(IN3, LOW);
digitalWrite(IN4, HIGH);
case 1:
digitalWrite(IN3, HIGH);
case 2:
digitalWrite(IN4, LOW);
case 3:
digitalWrite(IN2, HIGH);
case 4:
case 5:
digitalWrite(IN1, HIGH);
case 6:
case 7:
default:
