I am trying to use a stepper motor to make a hook lock mechanism, but once my code is entered, and the motor starts moving, it pauses, then starts moving again, and again and so on. How do I make it move a certain amount, and then stop moving altogether? The code that starts the motor is in the if statement.
#include <LiquidCrystal.h>
#include "IRremote.h"
#include <Stepper.h>
#include <SD.h>
const int stepsPerRevolution = 1500;
Stepper myStepper(stepsPerRevolution, 8, 10, 9, 11);
int IRpin = 0;
#define RED 1
#define GREEN 2
LiquidCrystal lcd (3, 4, 5, 6, 7, 13);
IRrecv irrecv(IRpin);
decode_results results;
void translateIR()
switch(results.value)
case 0xFFA25D: Serial.println("POWER"); break;
case 0xFFE21D: Serial.println("FUNC/STOP"); break;
case 0xFF629D: Serial.println("VOL+"); break;
case 0xFF22DD: Serial.println("FAST BACK"); break;
case 0xFF02FD: Serial.println("PAUSE"); break;
case 0xFFC23D: Serial.println("FAST FORWARD"); break;
case 0xFFE01F: Serial.println("DOWN"); break;
case 0xFFA857: Serial.println("VOL-"); break;
case 0xFF906F: Serial.println("UP"); break;
case 0xFF9867: Serial.println("EQ"); break;
case 0xFFB04F: Serial.println("ST/REPT"); break;
case 0xFF6897: lcd.print("0"); break;
case 0xFF30CF: lcd.print("1"); break;
case 0xFF18E7: lcd.print("2"); break;
case 0xFF7A85: lcd.print("3"); break;
case 0xFF10EF: lcd.print("4"); break;
case 0xFF38C7: lcd.print("5"); break;
case 0xFF5AA5: lcd.print("6"); break;
case 0xFF42BD: lcd.print("7"); break;
case 0xFF4AB5: lcd.print("8"); break;
case 0xFF52AD: lcd.print("9"); break;
case 0xFFFFFFFF: Serial.print(" REPEAT");break;
default:
Serial.println(" other button ");
lcd.begin(16, 2);
Serial.println("IR Receiver Button Decode");
irrecv.enableIRIn();
pinMode(RED, OUTPUT);
pinMode(GREEN, OUTPUT);
digitalWrite(RED, HIGH);
myStepper.setSpeed(20);
if (irrecv.decode(&results))
translateIR();
irrecv.resume();
int PinNum = digitalRead(IRpin);
lcd.setCursor(0, 0);
lcd.print("Locked ");
if (results.value == 0xFF18E7)
lcd.setCursor(0,0);
lcd.println("Unlocked ");
delay (1000);
digitalWrite(RED, LOW);
digitalWrite(GREEN, HIGH);
myStepper.step(1040);
return;
digitalWrite(GREEN, LOW);
lcd.setCursor(0, 1);
lcd.print ("Enter Pin");
lcd.setCursor(10, 1);
