good day im building an led matrix based on this link..
and i got it working
my problem is how to make it still ,
here is the code i used
const int numPatterns = 17;//this is the number of patterns you want to display
byte patterns[numPatterns][10]={space,M,A,D,E,space,B,Y,space,V,A,D,I,M,space};// the patterns order
void setup(){
pinMode(DataPin,OUTPUT);
pinMode(ClockPin,OUTPUT);
pinMode(LatchPin,OUTPUT);
//simple stuff here
pinMode(clock,OUTPUT);
pinMode(Reset,OUTPUT);
//reseting the 4017 IC, you have to do this
digitalWrite(Reset,HIGH);
delayMicroseconds(5);
digitalWrite(Reset,LOW);
void display_pattern(int loops)//int loop acts like a delay, it take 8 mSecands to scan all of the rows so int loops = 15 is a good time for it
for(x=0;x<numPatterns-1;x++){ // loop over the patterns
for (int z=0;z<8;z++){ //scrolls one bite at a time
for(int t=0;t<loops;t++){// the delay we get with loops
for(y=0;y<10;y++){// loops over the array of bytes
byte temp = patterns[x][y];
byte temp_2=patterns[x+1][y];
digitalWrite(LatchPin, 0);
shiftOut(DataPin, ClockPin,MSBFIRST,((temp<<z)+(temp_2>>7-z)));//writes digital outputs, Z is for how much bites it need to scroll
digitalWrite(LatchPin, 1);
delayMicroseconds(800);
shiftOut(DataPin, ClockPin,MSBFIRST,0);
digitalWrite(clock,HIGH);
digitalWrite(clock,LOW);
void loop(){
display_pattern(15);// calls for the display_pattern function and says that int loop = 15(if you do more loop the pattern whould scrrol slower).
the letters move from right to left. i have weak coding skill please help me
thanks
