Our device is a LAFVIN Mechanical 4WD Robot Arm Car V2.2. This is our code so far, would greatly appreciate your comments/suggestions for changes. Thank you!:
#include "IR_remote.h"
#include "keymap.h"
IRremote ir(3);
#include <Servo.h>
String BLE_val;
int base_degrees;
int arm_degrees;
int claw_degrees;
boolean forward_flag;
boolean backward_flag;
boolean left_flag;
boolean right_flag;
boolean claw_close_flag;
boolean claw_open_flag;
boolean arm_forward_flag;
boolean claw_recracted_flag;
boolean base_anticlockwise_flag;
boolean base_clockwise_flag;
boolean menory_action_flag;
boolean Avoidance_Function_flag;
boolean Following_Function_flag;
boolean Anti_drop_Function_flag;
boolean Line_tracking_Function_flag;
boolean Gravity_sensor_Function_flag;
int Left_Tra_Value;
int Center_Tra_Value;
int Right_Tra_Value;
int Black_Line;
int distance;
int actions_count;
int auto_count;
int low_speed;
int medium_speed;
int high_speed;
int speed_car;
int claw_read_degress[20]={0,0,0};
int arm_read_degress[20]={0,0,0};
int base_read_degress[20]={0,0,0};
Servo myservo1;
Servo myservo2;
Servo myservo3;
void read_degress() {
if (actions_count <= 19) {
claw_read_degress[(int)((actions_count + 1) - 1)] = myservo1.read();
delay(50);
arm_read_degress[(int)((actions_count + 1) - 1)] = myservo2.read();
delay(50);
base_read_degress[(int)((actions_count + 1) - 1)] = myservo3.read();
delay(50);
actions_count = actions_count + 1;
auto_count = actions_count;
Serial.println(auto_count);
void IR_control_Function() {
if (ir.getIrKey(ir.getCode(),1) == IR_KEYCODE_UP) {
Move_Forward(100);
delay(300);
Stop();
} else if (ir.getIrKey(ir.getCode(),1) == IR_KEYCODE_DOWN) {
Move_Backward(100);
delay(300);
Stop();
} else if (ir.getIrKey(ir.getCode(),1) == IR_KEYCODE_LEFT) {
Rotate_Left(70);
delay(300);
Stop();
} else if (ir.getIrKey(ir.getCode(),1) == IR_KEYCODE_RIGHT) {
Rotate_Right(70);
delay(300);
Stop();
} else if (ir.getIrKey(ir.getCode(),1) == IR_KEYCODE_OK) {
Stop();
} else if (false) {
} else if (false) {
} else if (ir.getIrKey(ir.getCode(),1) == IR_KEYCODE_7) {
claw_degrees = claw_degrees + 5;
if (claw_degrees >= 180) {
claw_degrees = 180;
myservo1.write(claw_degrees);
delay(2);
} else if (ir.getIrKey(ir.getCode(),1) == IR_KEYCODE_9) {
claw_degrees = claw_degrees - 5;
if (claw_degrees <= 50) {
claw_degrees = 50;
delay(2);
} else if (ir.getIrKey(ir.getCode(),1) == IR_KEYCODE_2) {
arm_degrees = arm_degrees + 5;
if (arm_degrees >= 180) {
arm_degrees = 180;
myservo2.write(arm_degrees);
delay(2);
} else if (ir.getIrKey(ir.getCode(),1) == IR_KEYCODE_8) {
arm_degrees = arm_degrees - 5;
if (arm_degrees <= 0) {
arm_degrees = 0;
delay(2);
} else if (ir.getIrKey(ir.getCode(),1) == IR_KEYCODE_4) {
base_degrees = base_degrees + 5;
if (base_degrees >= 180) {
base_degrees = 180;
myservo3.write(base_degrees);
delay(2);
} else if (ir.getIrKey(ir.getCode(),1) == IR_KEYCODE_6) {
base_degrees = base_degrees - 5;
if (base_degrees <= 0) {
base_degrees = 0;
delay(2);
void auto_do() {
if (0 != auto_count) {
menory_action_flag = true;
//hiii
actions_count = 0;
claw_degrees = myservo1.read();
arm_degrees = myservo2.read();
base_degrees = myservo3.read();
while (menory_action_flag) {
for (int i = (1); i <= (auto_count); i = i + (1)) {
if (Serial.read() == 's') {
menory_action_flag = false;
if (claw_degrees < claw_read_degress[(int)(i - 1)]) {
while (claw_degrees < claw_read_degress[(int)(i - 1)]) {
claw_degrees = claw_degrees + 1;
delay(15);
while (claw_degrees > claw_read_degress[(int)(i - 1)]) {
claw_degrees = claw_degrees - 1;
delay(15);
if (arm_degrees < arm_read_degress[(int)(i - 1)]) {
while (arm_degrees < arm_read_degress[(int)(i - 1)]) {
arm_degrees = arm_degrees + 1;
delay(15);
while (arm_degrees > arm_read_degress[(int)(i - 1)]) {
arm_degrees = arm_degrees - 1;
delay(15);
if (base_degrees < base_read_degress[(int)(i - 1)]) {
while (base_degrees < base_read_degress[(int)(i - 1)]) {
base_degrees = base_degrees + 1;
delay(15);
while (base_degrees > base_read_degress[(int)(i - 1)]) {
base_degrees = base_degrees - 1;
delay(15);
void claw_close() {
claw_close_flag = true;
while (claw_close_flag) {
Serial.println(claw_degrees);
delay(10);
claw_degrees = 180;
claw_close_flag = false;
void claw_open() {
delay(10);
claw_degrees = 50;
void arm_up() {
arm_forward_flag = true;
while (arm_forward_flag) {
delay(10);
Serial.println(arm_degrees);
arm_degrees = 180;
arm_forward_flag = false;
void arm_down() {
claw_recracted_flag = true;
while (claw_recracted_flag) {
delay(10);
arm_degrees = 0;
claw_recracted_flag = false;
void Stop() {
digitalWrite(2,LOW);
analogWrite(5,0);
digitalWrite(4,HIGH);
analogWrite(6,0);
void arm_base_anticlockwise() {
base_anticlockwise_flag = true;
while (base_anticlockwise_flag) {
Serial.println(base_degrees);
delay(10);
base_degrees = 180;
base_anticlockwise_flag = false;
void arm_base_clockwise() {
base_clockwise_flag = true;
while (base_clockwise_flag) {
delay(10);
base_degrees = 0;
base_clockwise_flag = false;
void Line_tracking_Function() {
Line_tracking_Function_flag = true;
while (Line_tracking_Function_flag) {
Left_Tra_Value = digitalRead(7);
Center_Tra_Value = digitalRead(8);
Right_Tra_Value = digitalRead(A1);
if (Left_Tra_Value != Black_Line && (Center_Tra_Value == Black_Line && Right_Tra_Value != Black_Line)) {
Move_Forward(120);
} else if (Left_Tra_Value == Black_Line && (Center_Tra_Value == Black_Line && Right_Tra_Value != Black_Line)) {
Rotate_Left(80);
} else if (Left_Tra_Value == Black_Line && (Center_Tra_Value != Black_Line && Right_Tra_Value != Black_Line)) {
Rotate_Left(120);
} else if (Left_Tra_Value != Black_Line && (Center_Tra_Value != Black_Line && Right_Tra_Value == Black_Line)) {
Rotate_Right(120);
} else if (Left_Tra_Value != Black_Line && (Center_Tra_Value == Black_Line && Right_Tra_Value == Black_Line)) {
Rotate_Right(80);
} else if (Left_Tra_Value == Black_Line && (Center_Tra_Value == Black_Line && Right_Tra_Value == Black_Line)) {
Stop();
if (Serial.read() == 'S') {
Line_tracking_Function_flag = false;
Stop();
void Move_Backward(int speed) {
analogWrite(5,speed);
analogWrite(6,speed);
float checkdistance() {
digitalWrite(12, LOW);
delayMicroseconds(2);
digitalWrite(12, HIGH);
delayMicroseconds(10);
float distance = pulseIn(13, HIGH) / 58.00;
delay(10);
return distance;
void Following_Function() {
int Following_distance = 0;
Following_Function_flag = true;
while (Following_Function_flag) {
Following_distance = checkdistance();
if (Following_distance < 15) {
Move_Backward(80);
} else if (15 <= Following_distance && Following_distance <= 20) {
Stop();
} else if (20 <= Following_distance && Following_distance <= 25) {
Move_Forward(80);
} else if (25 <= Following_distance && Following_distance <= 30) {
Move_Forward(100);
Stop();
Following_Function_flag = false;
Stop();
void Rotate_Left(int speed) {
digitalWrite(4,LOW);
void Rotate_Right(int speed) {
digitalWrite(2,HIGH);
void Move_Forward(int speed) {
void Anti_drop_Function() {
Anti_drop_Function_flag = true;
while (Anti_drop_Function_flag) {
if (Left_Tra_Value != Black_Line && (Center_Tra_Value != Black_Line && Right_Tra_Value != Black_Line)) {
Move_Forward(60);
Move_Backward(60);
delay(600);
Rotate_Left(60);
Anti_drop_Function_flag = false;
Stop();
void Move_backward_Function() {
backward_flag = true;
while (backward_flag) {
Move_Backward(speed_car);
backward_flag = false;
Stop();
void Move_forward_Function() {
while (forward_flag) {
Move_Forward(speed_car);
Stop();
void Avoidance_Function() {
int Avoidance_distance = 0;
Avoidance_Function_flag = true;
while (Avoidance_Function_flag) {
Avoidance_distance = checkdistance();
if (Avoidance_distance <= 25) {
if (Avoidance_distance <= 15) {
Stop();
delay(100);
Move_Backward(100);
delay(600);
Stop();
delay(100);
Rotate_Left(100);
delay(600);
Move_Forward(70);
Avoidance_Function_flag = false;
Stop();
void Turn_right_Function() {
right_flag = true;
while (right_flag) {
Rotate_Right(speed_car);
right_flag = false;
Stop();
void Turn_left_Function() {
left_flag = true;
while (left_flag) {
Rotate_Left(speed_car);
left_flag = false;
Stop();
char bluetooth_val;
void Gravity_sensor_Function() {
Gravity_sensor_Function_flag = true;
while (Gravity_sensor_Function_flag) {
if (Serial.available())
bluetooth_val = Serial.read();
Serial.println(bluetooth_val);
if (bluetooth_val == 'F') {
} else if (bluetooth_val == 'B') {
} else if (bluetooth_val == 'L') {
} else if (bluetooth_val == 'R') {
} else if (bluetooth_val == 'p') {
Stop();
} else if (bluetooth_val == 'X') {
speed_car = low_speed;
} else if (bluetooth_val == 'Y') {
speed_car = medium_speed;
} else if (bluetooth_val == 'Z') {
speed_car = high_speed;
if (bluetooth_val == 'S') {
Gravity_sensor_Function_flag = false;
Stop();
void setup(){
IRremote ir(3);
BLE_val = "";
base_degrees = 90;
arm_degrees = 90;
claw_degrees = 90;
left_flag = false;
right_flag = false;
claw_open_flag = false;
Left_Tra_Value = 1;
Center_Tra_Value = 1;
Right_Tra_Value = 1;
Black_Line = 1;
distance = 0;
actions_count = 0;
auto_count = 0;
low_speed = 60;
medium_speed = 120;
high_speed = 160;
speed_car = 60;
myservo1.attach(9);
myservo2.attach(10);
myservo3.attach(11);
Stop();
pinMode(2, OUTPUT);
pinMode(5, OUTPUT);
pinMode(4, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, INPUT);
pinMode(8, INPUT);
pinMode(A1, INPUT);
pinMode(12, OUTPUT);
pinMode(13, INPUT);
void loop(){
while (Serial.available() > 0) {
BLE_val = BLE_val + ((char)(Serial.read()));
delay(2);
if (0 < String(BLE_val).length() && 2 >= String(BLE_val).length()) {
Serial.println(String(BLE_val).length());
Serial.println(BLE_val);
switch (String(BLE_val).charAt(0)) {
case 'o':
claw_open();
case 'c':
claw_close();
case 'u':
arm_up();
case 'd':
arm_down();
case 'l':
arm_base_anticlockwise();
case 'r':
arm_base_clockwise();
case 'F':
Move_forward_Function();
case 'B':
Move_backward_Function();
case 'L':
Turn_left_Function();
case 'R':
Turn_right_Function();
case 'S':
Stop();
case 'm':
Serial.println(actions_count);
read_degress();
case 'a':
auto_do();
case 'X':
case 'Y':
case 'Z':
case 'A':
Avoidance_Function();
case 'D':
Anti_drop_Function();
case 'W':
Following_Function();
case 'T':
Line_tracking_Function();
case 'G':
Gravity_sensor_Function();
BLE_val = "";
BLE_val = "";
IR_control_Function();
