Hi all,
I'm just playing around the s/w serial library and I want to be able to read the values of these variables from my .ino file.
static char _receive_buffer[_SS_MAX_RX_BUFF];
static volatile uint8_t _receive_buffer_tail;
static volatile uint8_t _receive_buffer_head;
In the softwareserial.h, the above variables are declared under private so I just moved them to public as shown below. But during compile, when I reach the line trying to print the contents of _receive_buffer, I get the error: error: '_receive_buffer' was not declared in this scope
* Definitions
//#define _SS_MAX_RX_BUFF 64 // RX buffer size
#define _SS_MAX_RX_BUFF 256 // RX buffer size
#ifndef GCC_VERSION
#define GCC_VERSION (__GNUC__ * 10000 + __GNUC_MINOR__ * 100 + __GNUC_PATCHLEVEL__)
#endif
class SoftwareSerial : public Stream
private:
// per object data
uint8_t _receivePin;
uint8_t _receiveBitMask;
volatile uint8_t *_receivePortRegister;
uint8_t _transmitBitMask;
volatile uint8_t *_transmitPortRegister;
uint16_t _rx_delay_centering;
uint16_t _rx_delay_intrabit;
uint16_t _rx_delay_stopbit;
uint16_t _tx_delay;
uint16_t _buffer_overflow:1;
uint16_t _inverse_logic:1;
// static data
//static char _receive_buffer[_SS_MAX_RX_BUFF];
//static volatile uint8_t _receive_buffer_tail;
//static volatile uint8_t _receive_buffer_head;
static SoftwareSerial *active_object;
// private methods
void recv();
uint8_t rx_pin_read();
void tx_pin_write(uint8_t pin_state);
void setTX(uint8_t transmitPin);
void setRX(uint8_t receivePin);
// private static method for timing
static inline void tunedDelay(uint16_t delay);
public:
// public methods
SoftwareSerial(uint8_t receivePin, uint8_t transmitPin, bool inverse_logic = false);
~SoftwareSerial();
void begin(long speed);
bool listen();
void end();
bool isListening() { return this == active_object; }
bool overflow() { bool ret = _buffer_overflow; _buffer_overflow = false; return ret; }
int peek();
virtual size_t write(uint8_t byte);
virtual int read();
virtual int available();
virtual void flush();
using Print::write;
// public only for easy access by interrupt handlers
static inline void handle_interrupt();
// Arduino 0012 workaround
#undef int
#undef char
#undef long
#undef byte
#undef float
#undef abs
#undef round
#endif
Thanks in advance!
Alyas
